There is some drag thing on at EC on April 14th and there is an event for the girls - Lipstick Eliminator!!
Any chicks out there interested in attending?
Not sure if i want to enter a chick only event or just throw my lot in with the "street meet" section of the day! Will see how much interest there is :)
https://www.sau.com.au/forums/topic/106955-calling-all-chick-drag-racers/
  • Replies 68
Not sure if i want to enter a chick only event or just throw my lot in with the "street meet" section of the day! Will see how much interest there is :D
:lol: :domokun:
YEAH!!! awesome stuff liz :) and i agreee!!!!!
there isn't alot of info on the site, but just log onto
www.wsid.com.au.. go to event... look under april 14th... there is an entry form... select lipstick eliminator in the drop down box!!! DO IT LIZ!! let me know when you've entered ;)
ANewTattoo.. i don't think i know your real name?! :O Lizjane is also entering!! and so are you... RIGHT????
hehe.. :) 4 sau chickies!! bring it on!! we're going to own :)
To make it easier -
http://www.wsid.com.au/default.asp?Page=Event&ID=99
you can enter online...
i jsut did!! :) don't leave me hanging!!!!
yeah and chicks making the same times as everyone else will give you more recognition.. more prizes for you mona! maybe even sponsorship.. who knows!
im even thinking about putting a wig on and entering haha
well.. i called them.. you can enter the normal drags, and the lipstick eliminator... i think the eliminator is from 4pm nwards or something... so will jsut use one to practice for other!!
entering now!!
LOL!!!!!!!!!!!!!!!! do it joe! :)
and not sure if i'm something to aspire too! i don't preform well when evreyones watching! lol!
Moanie~~you forgot me already....just saw you in da citi last week and you asked me why i didn t go to the drag on Wed the week before... and i told you i was at work , thinking about going this time ...but not when you dont know who i am.... :P
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
