  • Replies 99
The gear knob comes with a sticker to put on your console to show the gears. The shipping method is that i wrap them up in paper and stick heaps of stamps on it. Works a treat
Hmm our office lady collectd the mail first thing this morning and there was some speakers for me but no Nismo Leather =( Where are they coming from? I would've expected they'd be here today if they were shipped Wednesday =\
Ya ditto... no show ;)
>.< Our 'business' mail centre is only open like 6-9 or some shit in the morning. WTF is that about, stupid PO BOX =( I'll hve to wait til monday :dry:
Edited by ActionDan
How do these gear knobs attach to the gear stick?
Do they have a plastic inner sleeve with a 10mm thread and a screw at the top (inside the knob)?
Fscking >.< I even stopped in on my way through to work to check the PO box this morning and still nothing >.< Nate, what address did you ship mine too or is this just Aus Post at their fscking finest >.<.
After spending all day saturday servicing and busting my ass then getting pulled over TWICE by the fuzz and possibly receiving 'an infringment notice in the mail', I could really use a new toy to make me happy ^_^
</rant>
Victory! It was in the PO box when I checked on the way home, fitted that bad boy right there in the car park, feels so direct =D
Question, where did people place the pattern sticker? I was going to leave it off but the local fuzz is quite adept at spotting mods on cars. On a recent check over the cop, who was a decent guy, knew to look at the boost solenoid, BOV, SMIC and so forth so I'd like to mount the sticker for legal reasons. I was thinking either on the ashtray door (can always replace the whole thing later if needed) or directly back from the knob, on the edge of the plastic surround.
Ideas? Thoughts? Pics?!
Cheers nate =D
In my opinion, the one that comes with it is a back tacky.
I've brought myself one of these to which I find to look alot better -
http://cgi.ebay.com.au/Nismo-5-Speed-Gear-...1QQcmdZViewItem
(no, this is NOT my auction, it is a idea put forward to make the gear sticker look better in my opinion)
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
