Ok, well I know that the PowerFC is obviously the best all round option however im wondering which will be the best solution for me. I have done plenty of searching and reading up on all three devices but im still not sure...
Currently I have the following mods;
Exhaust from turbo back
Greddy E-01
Filter
FMIC
Im not aiming for any big power numbers so im only planning on the following mods in the future;
Adjustable cam gear
Walbro fuel pump
CAI
From looking around on the net I'm thinking the devices are around the following price
S-AFC2 - $250 approx
E-Manage - $400/$500
PowerFC - $950
Now on top of this each device needs to be tuned, logic would tell me that the more programmable the device the m..ore its going to cost to tune. Does anyone have a rough idea of how much these will cost to tune?
Now... With what I want to achieve is it worth going the PowerFC? The main aim is to get a little more power, while making the power safer, hopefully with a little better fuel economy and getting the best bang for my buck...
The engine in questions is a RB25DET
Edited by Tragic
https://www.sau.com.au/forums/topic/107060-s-afc2-vs-e-manage-vs-powerfc/
just my view;
the walbro is crap dont bother, get a gtr33 pump
the emanage and safc are piggybacks and only give you half of the benefits.
the car will drive better, respond better, perform better and have more flexability with the powerfc.
dont bother with the emanage, its exensive get a cheaper EBC
get a good cold air intake
get a 3" turbo back exhaust with split dump before you fit any of these parts
that depends on how much money you have
you can make around %80 of what you need with the safc so it may be ok
there are great benefits with have stand alone engine management such as the powerfc
with benefits also comes cost
If it's a manual get a Power FC,
An SAFC won't fix the speed limiter
An SAFC won't allow independant adjustment of the ignition timing
An SAFC won't give you a full sensor diagnostics screen (Commander)
An SAFC won't show a dash warning for knock, injector duty or AFM voltage
An SAFC tune is a compromise tune (A/F ratio versus ignition timing)
etc etc
Think about it, an SAFC is ~$450 new and they sell used for ~$250.
A Power FC is ~$950 new and they sell used for ~$950.
It is pretty easy to see which is considered the best value.
:) cheers :)
Edited by Sydneykid
Thats what im thinking. I wanna keep the price down and I don't plan on upgrading the turbo.
What about the e-manage no one has really mentioned this? Is it a good inbetween? And how much do you think it would cost to get this tuned?
there is quiet considerable gains to be had as far as driving response and overall engine response.
the feeling on a well tuned rb25 with a powerfc is well beyond the stock ecu with a piggyback.
this is where the main benefits lie. you will probably end up with the same or similar max rwkw but thats not what is important. its how it drives and average power is what is important
the emanage is more expensive and by the time you set it all up with the harness and crap its probably just as much as the apexi powerfc.
so its clearly;
safc or apexi powerfc
ps; this topic and similar piggyback options have been discussed to death over and over, did you try a search? you will find lots of support for the apexi powerfc over piggyback
  • 2 months later...
you obviously havent researched much into emanage's??
An emanage can be purchased and delivered with ignition and injector harness for $490 delivered. Or alternatively you could purchase a car specific harness which including the unit it approx 530.
This means it bolts straight in and you can drive to the tune shop as it will have no adjustments made and be running what your ECU has set up.
Then just find someone who can tune it and you're set.
you can get by with an SAFC2 with the mods you have, if all you want to do is get your A/F ratios right, but that's about all they can do
E-manage is still a piggyback, but it's superior to the SAFC2 becuase you can adjust ignition timing.
i don't think this comment is justified, can you back this up with any examples of cars you have driven? and if so, how do you know it just isn't the tuner?
whilst a powerfc is superior to an emanage, they both allow you to do the same thing... adjust timing and fuel. now powerfc is easier to tune, but given enough time and an experienced tuner, an emanage can be tuned equally as well. So the question would more come down to features and ease of use.
my personal preference in ecu's leans towards the wolfv4 units, but I almost bought a powerfc for rb20 the other day because i found one for a price i couldn't turn up... At the end of the day, as long as it allows you to change timing and fuel, then it'll do the job.
Anyway, in general i'd prefer a full plug-in or stock remap over a piggyback anyday..... save up and go the pfc mate!
well having tuned my own powerfc i would likely to believe myself and feel the results for myself. how many tuners in melb can do the emanage? how long does it take to install? whats involved in installation?
the powerfc takes 5 minutes
i get to retain the stock ecu if i need
i remove every limit in the stock ecu
and its completely tuneable
what more would u need?
the cost is justified, and i think the powerfc is still cheaper than the emanage with harness
The emanage and harness is $530, how does that go more than $950?
The emanage allows you to retain stock ECU operations such as cold start and air conditioning. It does not need to be 'set up' as you could say and therefore would require less setting up time.
Emanage has similar functions that the PowerFC has, it lacks the ability to lower the rev limit however.
Any tune shop can tune an emanage if they're capable of oeprating a dyno. All it requires is the USB cable to connect to the emanage and the software. The same sort of set up with most aftermarket ECU's.
The USB cable can be purchased as well as software through nengun or greenlines online stores and is much cheaper than a hand controller. You just plug into your laptop install the software and you're tuning. Any 'home' tuner can adjust their air/fuel ratio's with a wideban sensor.
I have nothing against the PowerFC, it was more the fact that you approached it very one minded and just 'assumed' the emanage was a silly option when in fact for the money it costs, which is quite a lot less than the PowerFC, then the Emanage is quite a good aftermarket ECU option.
Edited by Mase
I don't like piggy backs because at the end of the day your just riding a stock ECU. I've found with piggy backs that the AFRs can change over time, and same with the ignition timing because the stock ECU plays with them and theres nothing you can do with it. What about when you do an ECU reset, your fuel/ignition maps are not right anymore because the ECU is starting to learn its fuel/ignition correction tables from scratch again. Chuck on bigger injectors/AFMs etc and you can just imagine how hard a piggy back is trying to fool the stock ECU. You can only do so much!
Stand alone you have complete control. emanages are for tightasses who cant go the extra mile and do it right with a PowerFC. All the talk about A/C and cold start etc is a completely non issue with PowerFCs. Hell it even has closed loop when tuned good. What more could you ask for, for the price? PowerFCs are so cheap now. Back in the day when they were closer to 2k then its understandable. Remember $500 difference at the end of the day when you add up the money you waste on modifying, is not much really.
Edited by Busky2k
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
