hello folks. i have had this car advertised on carsales for a while but no luck. i am asking 18k or closed offer, here are the specs...
96 rs4v silver. 100400 k's
rb25det
3" turbo back exhaust with high flow cat
hybrid front mount intercooler
manual boost controler and autometer gauge (10psi)
lockable thule 'aero' roof racks. $250.
the car has 4 small problems that i know about,
side mirror fold-in motors are just about had it.
small amount of rust showing under the side door mirrors. (apparently common, see pics)
minor scrape on rear left wheel arch (see pic)
a few areas of paint are scratched (not badly, see pics)
this car has been serviced regulary by tibrooks in adelaide and also r&g autos.
the 100 thousand kilometer service has been done and timing belt replaced.
i am the first australian owner and have had the car for 2 years. i paid just under 23 grand and have spend close to 3 grand on the mods, which have been proffesionally completed at exhaust technology in adelaide. (receipts provided see pics)
excellent opportunity to snatch up a turbo charged r33 skyline wagon!! :)
i am open to offers of cash and trade. for example, a s13 or r32 plus cash would be fine.
doug
0403018501
ps. see the post in the stagea forum for pics, or see the add on carsales.com.au.
http://carsales.com.au/pls/carsales/!c...rch_distance=25
Edited by surfstagea
https://www.sau.com.au/forums/topic/107103-modified-s1-stagea-rb25det-adelaide/
gday, kinda depends on what it is. do you have the 32 advertised anywhere? let me know the details. sorry for the pics not working, i can see them??? ill post them up here when i get time. it seems the thread in the stagea section has been closed! fussy moderators.... anyway check out the ones on carsales.com.au for now.
R32 type-M with
larger rotors R33 calipers
bomex front bar
GTR headlights
beeft up auto with cooler
R34 turbo
GFB boost controller
blitz turbo timer
toyo tpg tyers new on R33 rims
camber castor toe adjustable bushes
3 1/2 inch trust zorst not loud
6 months rego QLD
new belts and hoses full service just done
kenwood sound system new speakers in front and 7by9's in the back
Edited by xr8eater
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
