  • Replies 225
Originally posted by BigDatto
Hey UR2EZ,
Hasn't gone over your head, probably over your age !!
Hong Kong Phooey is circa 1977 - & it kind of took the p1ss out of itself a bit like the Simpsons. It was a pretty unique cartoon in its day and p1ss funny !!
Just 4 you....
And the lyrics to the theme song
"Hong Kong Phooey,
Number One Super Guy,
Hong Kong Phooey,
Quicker than the human eye…"
Damn,
I just read this post - and I knew the answer to the bonus 5 points question - Silverhawks is way eazzzy :(
How about Teenage Mutant Ninja Turtles ?! and also another cartoon I really enjoyed was Snorks :) and C.O.P.S & M.A.S.K :D
Also the Toxic Avenger cartoon was cool but that might been in the 90's :)
Firstly you bloody post-whores really need something to do with your spare time and secondly I cant remember the name of the cartoon but it had a bear that flew a plane and delivered parcels and shit from a seaplane and used to fight bad guys in planes and flew to this small "hawaiian" style club on this island.....and there was a younger bloke who used to grab a rope behind the plane and floated on a "air skateboard" It was on saturday disney in the mornings!!!
I'm at work now. What is there to do? I can sleep but I'n not tired yet.
This is what your looking for
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
