$60 Shipped
Brand new never opened at all heres a few details i found on it.. i brought 3 for me and 2 mates and one pulled out after i bought them..
G Tech /PRO Performance Meter:
Absolutely New In Box, Improved PRO Model !!
The G Tech Pro Performance Meter lets you quickly, accurately and simply measure the following performance and safety parameters:
* 0 to 60 mph time (0-100 Km/h)
* 1/4 mile elapsed time (E.T.)
* 1/4 mile trap speed
* Instantaneous lateral acceleration (G s)
* Sustained lateral acceleration (G s)
* 60 mph braking distance (100 - 0 Km/h)
* Instantaneous braking Gs
* Sustained braking Gs
* Horsepower
These units are brand new, never used and in original unopened cartons. Includes a G Tech Pro decal and all mounting hardware.
I recently checked the Gtech's accuracy at Calder Park and I can vouch for the accuracy of these unit. I ran a 13.8 sec 1/4 mile and the gtech reading was 13.85. So i can say first hand that these units are extremely accurate as per what the manufacturer claims ("accurate to within 1/100th of a sec)
The Gtech is perfect if your always performing new modifications to your car, and if you are wanting to see the effect these modifications has made.
Don't pay for expensive dyno tuning/readings, which can cost $75 per reading. Purchase the Gtech and it will pay itself off over and over again, saving you time and money spent at the workshop.
Do a 1/4 run or horsepower reading anytime you like!!
Don't pay the retail price of $399 in automotive stores such as autobarn.....Get it here for a fraction of the price
https://www.sau.com.au/forums/topic/107977-gtech-for-sale/
guy was meant to pick up a week ago.. now back up for sale first one to offer $60 gets it
I will take it! Please pm me with how you want the cash, COD or DD or what. Postage is to Sydney. Thanks!
https://www.sau.com.au/forums/topic/107977-gtech-for-sale/#findComment-2019098
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
