  • Replies 72
cool okay-
my mate with his swift needs some gear-box work done- he might bring it in tommorrow also.
10ish i'll try to be there at that time if i can-
I'll give you directions
If your going on Parramatta Rd towards the city its on the right hand side.
Its next door to AMPOL and baby co. If you see BP/Maccas that means you just passed it .
My mobile is 0413 955436
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
