Another Imports Cruise or Skylines Only Cruise???
ermmm ok boys take it to jerry springer!!
"battle of the liners"
hehe
anyways
i have not heard any suggestions from anyone as yet
come on put ur brains into gear and throw a few at me
when is the best time to hold this cruise for everyone?
or should i start another poll??
  • Replies 63
Originally posted by R31Nismoid
Hey!
my R31 will flog your 33 10 ways from sunday!
caravan or no caravan (must get a tow ball)  :bahaha:
But i like the idea of name tags!
Hi.. my name is Ash... and i have an addiction to Power  :crazy:
pity u cant flog him with a r31 engine and u have to use a r33 engine to do it:shake: :D
:D
Oh... so what? hehe!
still goes harder!
There are other r31's with Rb30ET's... one soon to be RB30DET.
and another RB30DETT.
don't worry... they aren't slow... a bit of jealousy i see here, :uh-huh:
And they are going just as hard as mine. If not harder.
but who's caring... we are all Sky's.
:grouphug:
"tow a caravan"
get the f**k outta here (said in a full sick wog accent, so dont take it literally)
i didnt buy a damn turbo r33 to tow a caravan, hahaha, u goon
if u want 1 u have 1, im just sayin i dont like em...
u might beat me, but proabably not, if so, not for long
and if u wanna talk which is quicker, welllll, look at 32, 33 and 34....plenty of 8sec cars there
il b impressed when a 31 cn run 8s (with a caravan if u want)
but even if u do...its still an ugly car
Originally posted by Ronin 09
If i'm not working, i'll be there for a Sky cruise... and to see Jet and Nismoid punch it out... :P
Who's punching out?
I'm just havin a bit of fun as Jet is ;)
like i said before...
peace
:grouphug:
I love my car and every performance aspect of it!! (Previously owned an XF falcon, on gas, with 300,000+ km's on it)
But i give respect to the 31's by saying this; The fastest drag time for a street car was done in a r31 powered by a rb30et. This has been a long standing record and has yet to be beaten.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
