  • Replies 131
Posted Images
Yeah what a great day so tired last night
The trip home was even more fun 800mm past the motel was a turn off to go to Colac / Geelong I took that to go home the first 50 km of that road were some of the best corners around, the next 100 kms think I only went around 10 corners in total
Here I was sitting on 100kph on a straight that was about 15 km long and I had a XR8 Ute come from nowhere and pass me I estimate the speed he passed me at was around 220 kph
Crazy F#$*(%G hick drivers keep it on the track not the road
Big thanks must go out to the slow drivers that pulled over to let the cars behind past and to the ones that didn’t please think of the others on the road next time
Nice pics ;)
Really wanted to go this year but had to miss something to get away and sadly this was it. Should have stayed here this week as Queensland weather was crap for 4 days. Reminds me of UK weather :)
I see the Telstar made it too!
BTW - Shan are you abusing your moderator powers with that post count :(
id have 2 agree with u there, that forrest has the most wikid roads around
Weee, just got home. Hell of a lot of fun even with sh!t front tyres. Next year need to organise ahead so that everyone knows the way around geelong, so we don't have to go through it :O
Great cruise guys, I had to go back on the first day after Anglesea because it was my brothers birthday, I wudve loved to have gone the whole trip.
So where are the pictures guys, hanging to see all of em!!!
Regards
Kim
Well it sounds like people had a ball out there! Once again another great event . Well done Ash and other organisers.
I hear the Commonwealth Games baton relay was out 12 Apostles way too. Did anyone happen to catch that crowd?
Who invited teh Telstar! along???
Hey
at least he didn't do it on blind corners like other people :O
finally made it home just now :P( my spine is permantly re aligned oh well, i definatly have to do my suspension!!!
cheers to all had great time
big thanks to organisers very well done
will throw some photos on soon as i organise it
tash. mel wants her foto up in members bit if your goin to post it :O and well email me mine and ill email you yours
cheers too all
What an awesome cruise and great bunch of members!!!
One of the most enjoyable cruises i had in a long time, well worth the overnight stay. Will definately be doing it again next year.
Got a few nice pics, will post them up some time this week.
Thanks to ALL, really represented SAU well.
Hope to see ya all again soon.
Alan
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
