Hey fellas,
I figured hundreds of pics of these two turbos have been posted on this website, but not in the one thread.
Can someone with both turbos post a pic of them side-by-side, with indications of ways to tell if you have one
or the other.
If no-one bothers, I might source pics of the forums and post them up here myself. Might be hard to work
out the difference!
Thanks,
Adrian.
https://www.sau.com.au/forums/topic/108640-rb20-and-rb25-turbo-pictures/
The wastegate isn't giant.. its the same size as the rb20 one, which you can see in the background. Thats one of the earliest RB20 ones (1989 model) so i think is a bit smaller.
They're not so identical.. the differences are more subtle visually.
1. Such as the point for the wastegate directly on the housing (mind you this is on the rb25 turbo, just hasn't been tapped out from factory).
2. The exhaust housing looks a bit fatter on the rb25
3. The inlet port is smaller and I think a little bit longer on RB20
And of course they have different markings. To the eye it seems more obvious I think.
Its a bit hard to tell when both are fitted and everything such as heatshield, etc is covering it up though.
yeah.. the rb25 ones have like 45vX where X = version number.. The rb20 I think are 16V
Its all covered somewhere you know :) You tend to forget things and think "oh it'll be on SAU if i need to find it" :)
Thanks buddy, I'll check it out.
Top work GTST. Can you post up the actual measurements you got on those impellers?
If they are still apart, then try to get the size of the inducer (smaller end) of the compressor as well. This will allow us to calculate the trim size.
cheers
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
