Anyone going to the MCCR meet tomorrow Night?
  • Replies 61
Originally posted by Horus
oooooooohhhhhhhhhhhhhhhh
....give it 6-8 months and after Ive done the SR20DET conversion, we will see whos laffin :)
well......regardless of how much time you want to give us, if you feel the urge to go to MCCR meets, then we're still going to be laffing :uh-huh: ;)
i was thinkin of goin to that meet, seein as all my mates were gonna go, but then recently everytime MCCR organises sumfin publicly, the cops always end up canaryin'g about 20 cars, and I dun wanna be one of em.
and with the recent blitz on imports hapening (4 million dollar project) i dun wanna be seen in a mass gathering of imports, it'll be a field day for em.
lol
i went
was a great turn out
i know i will get flamed for this
but i must say it was actually quite a good cruise
and no cop hassels at all
we had highway patrol actually accompaning the cruise
no problems from them at all
considering the amount off very illegal cars that attended!
:D
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
