Using the right tool he 'may' be ok with the majority of stuff as the previous windows xp install would have installed in roughtly the same physical position on the disk. Then the user would have added his personal files.
Run an undelete tool, see what you can get off.
Myself... I like to run 2 partitions. One for windows and programs and one for my docs and other crap.
Re-installs are then hassle free.
  • 4 weeks later...
Imageready in Paint Shop. Hmm... didn't think to have a look at that app. Thanks :)
I have a mate thats into all the Paint Shop Pro stuff. Might have to hit him up on it.
$99 good work :worship:
Ok, my work pc is giving me the shites (well, headaches anyway)
Pentium 3.2 with the standard L775 fan
The fan has gone bonkas and is SO loud. How do I replace it? I cant see how the fan comes off - do you actually need to take out the motherboard to get access to the back side of the MB to undo screws that hold in a L775 P4 fan?
Im a bit lost as to how to take out the standard fan.
i hope this help isnt too late
the top of the circle has a slot to put a flat head screwdriver in it from memory u turn anticlockwise to take the HSF off you will need to do it too all of them... you will know when youve got it right
mine looks a little different because its not OEM fan anymore
cheers lads......... nuh not dusty, nor will I be spraying silicone into the MB of the sole work PC. Ive got the exact same fan at my home pc, both 1yr old, and both making an 'off centre' spinning noise - dropped a bearing ? ? ;)
got a 'golden orb' big arsed copper fan to replace one of them (probably the work pc first, then look at mine at home)
    • Is this where I say "Hey man my airbox cost me horsepower in my Naturally Aspirated Engine"? (I know you need them for legality in NSW)
    • 1.5mm alloy folded up, it will need a tweek, as the angled bend only got to around 45° as that was the max that the break press would get with the other bends, and I needed a fair bit more, but and the alloy is easy to bend too my will by hand once I trim the lower section out I'll Dremel out and form the angle and mounting point on the lower section when time permits  As for the lid, I'm looking at going a "cap", instead of a flat lid to hide the fixtures a bit
    • I got sick of thinking about batteries so just kept buying chargers. I've got a ctek (racecar), a "noco" thing from supercheap (tow car with 2 batteries), and an old "SupaCharge" branded lead acid thing (farm ute/mower) and will need 1 more when the Silvia gets a battery again (if the 86 stays).  I always make sure the charger itself is in free space/away from car etc, just to be sure.
    • The "long nose" diffs in your type of car, that have the speed sensor on the snout, are a pain because the casing is different from all the other short nose diffs. This means that the pinion shaft inside them is longer, which can make it harder to do certain types of diff swaps. But, if all you are going to do it swap the diff centre, and keep the gears (that's the crownwheel and pinion gears) then you won't have any problems.
