Using the right tool he 'may' be ok with the majority of stuff as the previous windows xp install would have installed in roughtly the same physical position on the disk. Then the user would have added his personal files.
Run an undelete tool, see what you can get off.
Myself... I like to run 2 partitions. One for windows and programs and one for my docs and other crap.
Re-installs are then hassle free.
  • 4 weeks later...
Imageready in Paint Shop. Hmm... didn't think to have a look at that app. Thanks :)
I have a mate thats into all the Paint Shop Pro stuff. Might have to hit him up on it.
$99 good work :worship:
Ok, my work pc is giving me the shites (well, headaches anyway)
Pentium 3.2 with the standard L775 fan
The fan has gone bonkas and is SO loud. How do I replace it? I cant see how the fan comes off - do you actually need to take out the motherboard to get access to the back side of the MB to undo screws that hold in a L775 P4 fan?
Im a bit lost as to how to take out the standard fan.
i hope this help isnt too late
the top of the circle has a slot to put a flat head screwdriver in it from memory u turn anticlockwise to take the HSF off you will need to do it too all of them... you will know when youve got it right
mine looks a little different because its not OEM fan anymore
cheers lads......... nuh not dusty, nor will I be spraying silicone into the MB of the sole work PC. Ive got the exact same fan at my home pc, both 1yr old, and both making an 'off centre' spinning noise - dropped a bearing ? ? ;)
got a 'golden orb' big arsed copper fan to replace one of them (probably the work pc first, then look at mine at home)
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
    • Tomei or Nitto, don't use the OEM one or Cosmetic ☺️
    • After cleaning up a rusty cooling system in a 33 gtst that's been sitting for years it seems to have cleaned out the head gasket too haha. It seems the Tomei metal gasket works without machining surfaces? Or put oem? Also should put an oil restrictor while the head is off? Thanks
    • Thanks, I definitely saw the more expensive options from Crank and driveshaft shop. Thank you for the D-max option.  Still hopeful someone has an OEM out of the box option I found that the 300zx NA Left drive shaft is a good match for the Right on the R33. https://www.gsplatinamerica.com/product/ncv53040 Just need to find Left CV for the R33, I cannot find any <=22" axles.
