welcome to teh interwebs boys.
My personal opinion = waste of time buying consoles for gaming.
Computer for me always.
lol x2 cant agree more
but the console if good for when a couple of mates come over you got the Gran Tarismo few drinks under your belt and eveyones a race car driver
haha no it won't.
Metal gear is set for March next year. Why would sony release probably the two biggest franchises newest games at the same time lol.
Also masively avaible and worthwile? what are you on about?
Because Sony dont release them. and from past history, they have always seemed to be released around the same times, i mean... Gran Turismo is in its 4th intallment, and so will Metal Gear be in its 4th installment.
They will be released within 1 month of eachother is my prediction.
To answer your question Kralster, to make more money.
You'll have Grant Turismo edition PS3 console packages, and Metal Gear Solid 4 ones and etc. As it has happened in the past with the Playstation.
And Steve, the Cell processor is more advanced than Intel's Core 2. IBM plans a comeback with using it in its future computers and laptops, not sure if itll run Windows though.
So you've gone from saying released at the same time to a month after each other. I agree a month later for one of the titles would be a good idea. But i don't see the next gran turismo being finished until late next year at the earliest.
Gran Turismo - May 1998
Metal Gear Solid Febuary 99 (9 months later)
Gran Turismo 2 - October 2000
Metal Gear Solid 2 March 2002 (17 months later)
Gran Turismo 3 - July 2001
Metal Gear Solid 3 - March 2005 (over 4 years later)
Gran Turismo 4 - March 2005
Metal Gear Solid 4 - Still TBC but March 2008 current release schedule (over 3 years)
I don't see how in past history they have been close to each other.
well if ur going by those dates and look more at the japanese release ones NTSC i think they are much much closer.
Same time I meant more around the same quarter. I can see GT5 being released around June next year.
Now your saying June next year. Before you were saying the same time a MGS4, than about a month later, now 3 months later.
And the release dates for those games in japan were also with about the same distance between them.
Also playstation 1 and 2 consoles have only ever been bundled with first party sony titles. There may of been soft bundles with games from 3rd party developers, but never in the same box.
Anyways.
What do you think of quake wars Madaz?
I don't mind it myself, not what it was hyped up to be but then again, what is these days?
dont hate it prefer GRAW2 though i like the more realistic looking skins than set in the future
im a little excited over COD4 not being WW2 shooter that might be one to watch out for
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
