  Madaz said:
lol you just havnt seen the light
i had a x800xt pe from factory it was overclocked and shouldnt of been and used to get hot so i sent it back and Aust. Post lost it
so i collected $800 for insurance and looked into 7800GTX for $850 was expecting it to blow the x800 away but it didnt so i took it back for a full refund and waited and got the X1900xtx
  KISIN said:
well i just d/l this and will give it a go see what its like.
this man does alot of waiting...
and vlad, in ur little dream world lol.
i recon that war rock has been a beta for a while not sure though
getting now
EDIT yes i was correct
War Rock Open Beta Client PC
Edited by Madaz
  Pauly33GTS-t said:
well i just got a good offer on 2 8800GTS so im now SLI.
Im selling my 7950GX2 for 300 dollars to anyone thats interested, thats a firm price.
On another note, say I have a computer thats drawing 450watts, what would I need to put it in the car and have it run?
$300 is a real good price, for sure.
450 watts on a 12 volt system is 37.5 amps.
You'd need a power inverter, like this one:
LINK HERE
They say 90% max efficiency, so it would draw around 42 amps, and I'm not sure what skyline alternators are rated at.
Not a cheap proposition, but possible.
Probably not a great idea for long periods.
lol yeah.... cost of that?
Hey im running the 8800GTS's in SLI on an Antec 550w Trupower 2.0 PSU...
I think I need to upgrade my PSU as after maybe 40 mins or so of gaming I get a BSOD or on one occasion the power just went out.
Here are my specs:
Antec 900 gaming case 5 fans (1x 200mm exhaust fan, 1x 120mm exhaust fan, 3x 120mm fans)
Thermaltake Blue Orb CPU fan (My water works is in the works)
Core 2 Duo E6600 running at stock speed
Asus P5NSLI motherboard
4GB of DDR2-800 @ 1.8v (The Elixr shit)
Pioneer DVDRW combo drive
LG DVD drive (generic)
2x 250gb 7500rpm Seagate SATA2 drives.
2x MSI 8800GTS OC in SLI
Antec True Power 550w PSU (SLI Certified hehe for what). http://www.antec.com/us/productDetails.php?ProdID=23550
Now, I bought these 2 cards for cheaper than a Ultra and at the resolution I run games at on a WS this card is faster than a 8800 Ultra.
But Ultimately, what PSU would I need. I noticed tangles I think it was is selling his PSU, would that be suitable?
Edited by Pauly33GTS-t
my psu is great
650 up to 700w
plug-in braided lines, quality is right up there IMO
why Im going higher? - well, it has 2 only connectors for 6pin pcie
with my 2900xt's I need 4 connectors for 6pin pcie (and have bought 2x 6pin-8pin converters)
this 650w psu I have worked beautifully with 2x 7800GTX's MSI brand 256b each on full bore
Well tangles, tell me this, would you be confortable powering quad sli 2 7950GX2 with that PSU?
cause the 8800GTS draws the same power if not just a touch more on my card compared the the 7950GX2 and the recomended is 700w for my setup.
I am bidding for an enermax galaxy 1000w on ebay, should be good enough...
lol
why no, no I wouldnt
Id look for a 750w unit like a Thermaltake Toughpower, or even a SuperFlower Aurora 750w
hehehehe :bunny:
all good, got 10 watchers for it on ebay atm
(shamless plug for the winnnnnah)
fark i just read its been measured that my SLI setup draws 340-390watts at full load on 3d mark 06....
and i am using a 550w power supply atm, my graphics are chewing up resources, shit.
Maybe i can use sli in the meantime by powering off a HDD and the optical drives... 4 sticks of ram, a mother board and a 65w E6600 + 390w max f**k too much maths give me a beer.
  beerbaron said:
anyone here MCSA certified ? or CCNA certified ?
i need to do get these certifications for work
Yeah I did CCNA at school for $400, the joys of my school paying for the bulk of it. What do you want to know?
Its a peice of piss and to be honest unless you are working with cisco equipment it really doesn't teach you that much.
Edited by Rolls
well.. f**k me im lacking 300 or so watts... ill have them soon tho... weird thing is its working properly so maybe my PSU has a good source of power and wattage on the 12v rails. wierd.
EA Sports are some of the worst games going around.
If you want a decent soccer game play Winning 11 (Pro evo in australia) and for basketball play the 2K sports games, formally SEGA sports.
Much better than anything EA make.
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
