lol you just havnt seen the light
i had a x800xt pe from factory it was overclocked and shouldnt of been and used to get hot so i sent it back and Aust. Post lost it
so i collected $800 for insurance and looked into 7800GTX for $850 was expecting it to blow the x800 away but it didnt so i took it back for a full refund and waited and got the X1900xtx
well i just d/l this and will give it a go see what its like.
this man does alot of waiting...
and vlad, in ur little dream world lol.
i recon that war rock has been a beta for a while not sure though
getting now
EDIT yes i was correct
War Rock Open Beta Client PC
Edited by Madaz
well i just got a good offer on 2 8800GTS so im now SLI.
Im selling my 7950GX2 for 300 dollars to anyone thats interested, thats a firm price.
On another note, say I have a computer thats drawing 450watts, what would I need to put it in the car and have it run?
$300 is a real good price, for sure.
450 watts on a 12 volt system is 37.5 amps.
You'd need a power inverter, like this one:
LINK HERE
They say 90% max efficiency, so it would draw around 42 amps, and I'm not sure what skyline alternators are rated at.
Not a cheap proposition, but possible.
Probably not a great idea for long periods.
lol yeah.... cost of that?
Hey im running the 8800GTS's in SLI on an Antec 550w Trupower 2.0 PSU...
I think I need to upgrade my PSU as after maybe 40 mins or so of gaming I get a BSOD or on one occasion the power just went out.
Here are my specs:
Antec 900 gaming case 5 fans (1x 200mm exhaust fan, 1x 120mm exhaust fan, 3x 120mm fans)
Thermaltake Blue Orb CPU fan (My water works is in the works)
Core 2 Duo E6600 running at stock speed
Asus P5NSLI motherboard
4GB of DDR2-800 @ 1.8v (The Elixr shit)
Pioneer DVDRW combo drive
LG DVD drive (generic)
2x 250gb 7500rpm Seagate SATA2 drives.
2x MSI 8800GTS OC in SLI
Antec True Power 550w PSU (SLI Certified hehe for what). http://www.antec.com/us/productDetails.php?ProdID=23550
Now, I bought these 2 cards for cheaper than a Ultra and at the resolution I run games at on a WS this card is faster than a 8800 Ultra.
But Ultimately, what PSU would I need. I noticed tangles I think it was is selling his PSU, would that be suitable?
Edited by Pauly33GTS-t
my psu is great
650 up to 700w
plug-in braided lines, quality is right up there IMO
why Im going higher? - well, it has 2 only connectors for 6pin pcie
with my 2900xt's I need 4 connectors for 6pin pcie (and have bought 2x 6pin-8pin converters)
this 650w psu I have worked beautifully with 2x 7800GTX's MSI brand 256b each on full bore
Well tangles, tell me this, would you be confortable powering quad sli 2 7950GX2 with that PSU?
cause the 8800GTS draws the same power if not just a touch more on my card compared the the 7950GX2 and the recomended is 700w for my setup.
I am bidding for an enermax galaxy 1000w on ebay, should be good enough...
lol
why no, no I wouldnt
Id look for a 750w unit like a Thermaltake Toughpower, or even a SuperFlower Aurora 750w
hehehehe :bunny:
all good, got 10 watchers for it on ebay atm
(shamless plug for the winnnnnah)
fark i just read its been measured that my SLI setup draws 340-390watts at full load on 3d mark 06....
and i am using a 550w power supply atm, my graphics are chewing up resources, shit.
Maybe i can use sli in the meantime by powering off a HDD and the optical drives... 4 sticks of ram, a mother board and a 65w E6600 + 390w max f**k too much maths give me a beer.
anyone here MCSA certified ? or CCNA certified ?
i need to do get these certifications for work
Yeah I did CCNA at school for $400, the joys of my school paying for the bulk of it. What do you want to know?
Its a peice of piss and to be honest unless you are working with cisco equipment it really doesn't teach you that much.
Edited by Rolls
well.. f**k me im lacking 300 or so watts... ill have them soon tho... weird thing is its working properly so maybe my PSU has a good source of power and wattage on the 12v rails. wierd.
EA Sports are some of the worst games going around.
If you want a decent soccer game play Winning 11 (Pro evo in australia) and for basketball play the 2K sports games, formally SEGA sports.
Much better than anything EA make.
    • So my rb is finally having more problems. 2 issues here but I'm here to just to mainly discuss the rattle noise. The other day when I turned on the car and when I take off or go in reverse, there is a temporary rattle noise but when I cruise, boost, idle it's completely fine no rattle whatsoever. I've also done all the servicing, all the health checks you can think of and it all passes with flying colours.  Also the rattle doesn't increase with rpm, it's only at a very certain rpm (slightly above 1,100rpm). My other car also has the same issue every once in a while. Changed the oil recently, no difference. Even took my oil to a lab and everything was quite good surprisingly. Timing belt changed a while ago to. Had the car on the hoist and can't see anything obvious. Tightened a couple of nuts on the exhaust manifold a couple of months ago. 2 different clips uploaded. One of them was supposed to another issue but I'll save that for another time. Thought I'd see if anyone had this same noise before, it's a bit hard to diagnose while it's intermittent. If I'm not mistaken, I think I had this a while back but can't remember exactly. I was thinking if it's doable I'll get someone to hold the throttle cable at 1,100rpm and hopefully it replicates the sound. rb25det rattle only.mp4 rb25det slow start + rattle.mp4
    • Haha wow, yes they do! Will sort tomorrow.
    • Yeah I’ll know when I take it for a test drive and I’ll double check the turbos as well when I have a look at it again.  Just thought maybe they might have done something in the head cause it looks like they’ve taken off the rocker covers 🤔 Thanks for your info!
    • As Duncan mentioned it's likely a remapped ECU, like the the one listed in the link I post earlier:  https://minkara.carview.co.jp/userid/444260/car/444612/2099320/parts.aspx He quoted 444PS with an unopened engine and twin GT2510s @ 1.1bar boost... sounds about right?
