is there anyway to force a boot from disc without going through the BIOS?
when i turn on my PC i have my 2 drives C & D (either DVD rom or 2nd HD) and can use them both fine. if i do a restart the D Drive disappears.
I have been trying to reformat but when i set the DVD rom as the priority device in the BIOS i loose it when it it exits and restarts.
its really starting to piss me off. I tried to reinstall windows from the desktop but i only have a cd with service pack 1 and my pc has service pack 2 so it won't allow me to install the older one over the top :mellow:
sorry if it is hard to follow i'm not really sure how to explain it
Edited by Whiplash
its really starting to piss me off. I tried to reinstall windows from the desktop but i only have a cd with service pack 1 and my pc has service pack 2 so it won't allow me to install the older one over the top :(
normally F8 will bring up a bios boot selection menu (not actually enteringinto bios, just gives you a choice of what to boot from). If this is a pioneer 112 dvd burner we are talking about, go get it replaced at the store you bought it from... oh also not everyone uses F8 for the boot menu, so you may need to look round at the start of the boot and see if it gives you and hint as to what they could be using
just had a go of the new Sega Rally very nice indeed and thats on a old system like mine too a while to load and only has support for keyboard but looks promising but so does the new drfit trailer for need for speed pro street
Sega Rally: Revolution 580mb GameArena DEMO
Sega Rally: Revolution 553mb Internode DEMO
New Trailer showcasing Drift on NFS:PS
NFS:PS Drift GameArena 40mb
THIS IS HIGH RES version of above
NFS:PS Drift Trailer 143mb Internode
Edited by Madaz
Can any of you tell me why this is awesome lol...
http://img138.imageshack.us/img138/9763/17102007027mb0.jpg
I get my new ASUS board today... and just as I expected. Fun fun fun...
btw, UT3 is awesome, definitely buying it.
I got MOHA, single player is great, multiplayer less so pre-patch, after 1.1 now its sorta ok, you stand a chance from snipers and sprayers in MOHA but there isnt many Aussie servers so dont buy it for the MP even tho I think its better than COD2's mp, ie less fustrating.
Edited by Pauly33GTS-t
hey chops, I actually have bought the new revision of the p5n32-e-sli board, they are build on the same Striker Extreme motherboard, with the same bios, but less cooling and a few less solid capacitors. Still kicks ass though, enjoying it so far.
CPU: Core 2 Duo E6850 3.0Ghz 4mb L2 cache 3000mhz @ ~3400mhz
Memory: 4095mb DDR2-800
Motherboard: ASUSTeK Computer INC. P5N32-E SLI
Graphics Cards Manufacturer: MSI/Nvidia
Dual NVIDIA GPUs: 2x MSI GeForce 8800GTS-OC Edition cards
Sound: Asus 7.1 Supreme FX add-on card
Hard Drive(s): C:\ (149.0 GB)|D:\ (232.9 GB)|E:\ (111.8 GB)
got parts for a 2nd pc for the wife/kids (just need screen&case)
here's mine, 3DMark06 score of 16692 http://service.futuremark.com/orb/projectd...projectType=14:
Thermaltake Soprano case
Coolermaster Realpower Pro 850w PSU
Asus P5W DH Deluxe motherboard
Coolermaster R120 cpu watercooling kit
Intel Quad Core Q6600 2.4mhz overclocked to 3.3mhz
OCZ 4x 1gb 667mhz overclocked to 732mhz
Seagate 2x 200gb Sata HD in Raid-0 configuration
Seagate 80gb Sata HD backup
ATi Xpertvision 2x 2900XT 512mb pci-e dx10 graphics cards in Crossfire mode
Creative X-Fi Fatality Pro XtremeGamer soundcard
Zalman 5.1 6ch headset & mic, Solman 5.1 6ch sub/speakers
Logitch G5 mouse, G15 keyboard
Cmv 19” LCD screen
LG Dvd-Rw, Sony 1.44 Fdd
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
