  • 3 months later...
Thought I'd dig up this old thread :D and show off some of my 3d work i have been doing
http://www.skylinesaustralia.com/forums/3d-Art-t204712.html
also anyone else here been playing COD4 online (PC)? if so whats your name???? i'll be going under [RUPES] 1 or useless depends on the day and if my mates are on line
Edited by Whiplash
Yeah I finished COD4 single player in about 8 hours - was a lot of fun. Don't play it online though.
I have just built myself a new AMD Phenom 9500 Quad Core rig with all the usual fruit 4Gb DDR2 1066Mhz, 1.5Tb total hard drives, blah blah blah. Damn it runs quickly!
ok i usually play anywhere there are empty slots :D i have a good habit of getting more assists than kills. In 1 map i ended up with 40 kills 46 assists and 30 deaths. I couldn't believe it and there were heaps of people commenting on it as well was funny. I usually log in with my mate MJ who is a freak at the game 9/10 times he will win a match with 60+ kills.
nice you should play online it goes off, by far the most intense online game i have played (but thats not saying much as its really the first online game i have got into :D)
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
