  • 3 months later...
Thought I'd dig up this old thread :D and show off some of my 3d work i have been doing
http://www.skylinesaustralia.com/forums/3d-Art-t204712.html
also anyone else here been playing COD4 online (PC)? if so whats your name???? i'll be going under [RUPES] 1 or useless depends on the day and if my mates are on line
Edited by Whiplash
Yeah I finished COD4 single player in about 8 hours - was a lot of fun. Don't play it online though.
I have just built myself a new AMD Phenom 9500 Quad Core rig with all the usual fruit 4Gb DDR2 1066Mhz, 1.5Tb total hard drives, blah blah blah. Damn it runs quickly!
ok i usually play anywhere there are empty slots :D i have a good habit of getting more assists than kills. In 1 map i ended up with 40 kills 46 assists and 30 deaths. I couldn't believe it and there were heaps of people commenting on it as well was funny. I usually log in with my mate MJ who is a freak at the game 9/10 times he will win a match with 60+ kills.
nice you should play online it goes off, by far the most intense online game i have played (but thats not saying much as its really the first online game i have got into :D)
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
