COGS aka The Arena download that its a game browser you will need to make a free account will take you 5 mins max
er I don't think my CD key will work online *coff coff*.
But I still have a few hours of reports to type yet tonight, so no games for me :D
Andrew you just need to know server admins to relax PB_duplicate id's :P
yeah i had that problem for some reason as well for a little while *wink wink nudge nudge* but manged to sort that problem out. then i just had to fight with punkbuster cos it kept on kicking me out for having a name that was to short :P
all the servers are there nick its a easy way to see if your mate is in the server and how many people are in servers before loading up the game
thats how i copy and pasted that server description and ip before
so are you MJ or is he??
ok i usually play anywhere there are empty slots :D i have a good habit of getting more assists than kills. In 1 map i ended up with 40 kills 46 assists and 30 deaths. I couldn't believe it and there were heaps of people commenting on it as well was funny. I usually log in with my mate MJ who is a freak at the game 9/10 times he will win a match with 60+ kills.
i wouldn't say freak more so cheat, very suspect some of those kill cams
Yeah I finished COD4 single player in about 8 hours - was a lot of fun. Don't play it online though.
I have just built myself a new AMD Phenom 9500 Quad Core rig with all the usual fruit 4Gb DDR2 1066Mhz, 1.5Tb total hard drives, blah blah blah. Damn it runs quickly!
How are you finding the new Phenom processor Andrew?
What i've mostly read hasn't been that positive. And the chipset and socket seem to be just an extension of AM2.
And do they only run a 800 mhz bus?
finally there's some cs gaming happening around SAU :)
been waiting for a long time fellas, I play under the nick of "neverdie" or "neverdie@arena". Usually I play in GA servers, might see you all in there..... :no:
as if you play counter strike when there is COD4 :)
time for an upgrade i think, my current PC is 3 years old and not coping well with well everything :) have to wait and see what happens with work
haha would you believe I actually own Double Dragon - I have the jamma board in my arcade machine (which is for sale if anyone is interested). A mate and I finished it again just a few weekss ago. Classic game!
  • 3 weeks later...
been having a look at some ferrari 430 software this weekend. Some pretty in depth stuff there. Unfortunately it had a mind of its own and seemed to take control of the car. in qualifying it was controling the brakes when it wanted to brake (not that helpful down the straights when the cars brakes are locked on) and the in the races it decided that it would go into neutral instead of the gear it was meant to - see what happens when you rely to much on computers.....
it makes you ferrari slow!!!!!
oh and i found the laptop i want, the Lamborghini Asus specially developed to work with the Gallardo software and diagnostic tools. it has a sexy carbon outer case with the raging bull embossed into the top
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
