All I'm saying is I too was just like yourself until the Core2 Duo systems..
For a 'normal' gaming system for some one with a budget they are far better off running decent brand cheaper ram like Kingston, supertalent or A-data and then pushing the $$ they save in to possibly more ram, better hard drive, bigger monitor or a cpu with a higher multi.
Upgrade have a play and see how much ram really does not affect the performance of a c2d system; $$ much better invested else where.
It really is considerably different to the old AMD's and how they really love low latency and fast ram.
With the C2D systems if you are squeezing the system and pushing over 400fsb (800ddr2) and max'd out the cpu's multi grab that quicker ram as its most definitely beneficial as it allows a quicker cpu. If not well its simply money wasted.
If you hunt around there's a few articles on the c2d system, latency, ram speed and fsb speed and how its all fairly immune. My findings are the same. Raw clock speed FTW. :P
Upgrade have a play and see how much ram really does not affect the performance of a c2d system; $ much better invested else where.
Yeah but Im anal about stuff and I dont do it by halves. I just did a quick shopbot search for the components that I'd need to justify the upgrade and it takes me to $2k easily ;P Money I'm gonna be spending on new gearbox and buying the conzult/eee combo :P
-D
With respect to my system, which is what post was quoted with regard to DDR2-800 RAM - I'm not an overclocker.
I prefer to buy reasonable hardware that will do all I ask of it for as long as I want it to perform.
I don't need every last iota of performance from my pc, just something pretty solid.
With regard to the guy looking to build a new system - what are you looking to spend, and what do you have already that you can carry over, like a screen for example.
You say you want a gaming machine, but what kinds of games will you play?
I'm not having a dig at anyone, but people seem to find it very easy to spend someone elses money on a forum - you are the one that has to live with the choices - you don't have to spend $5k on a gaming system to have fun.
I recently spent...
M/board - $130
CPU - $90
4GB ram - $90
Vid - $100
Has no issues running GRID at 1680x1050 with medium settings; BF2 at full settings, COD4 at medium.
The cpu is clocked to 3ghz on stock volts (333x9); ram running at 800mhz.
Runs perfectly the young lad loves it in GRID; dropping burnouts and putting the brake on as he puts it. :P
It runs the games I like most quite well; COD4 and BF2.
Hell even Crysis it did damn well.
The system is not cpu bound so throwing a better vid card at it will no doubt increase in game performance noticeably.
Its still running on an old Antec 380w truepower that I recapped a couple of yearse ago due to the typical leaky fuji caps.
The PSU seems to be handling it well and given the watt calc requirements it should be perfectly fine.
Realistically the only time you require a topline PSU is when running the super hungry GX2 failing that a Seasonic 430w or 550 will cut it for all other applications unless your some hard drive whore. :D
Cubes, I have an Antec TP3 550 that died on me pretty early - I think it was still in warranty but I couldn't find the receipt.
Could you have a look at it for me possibly? - it's a brick at the moment so if you kiled it trying to fix it there wouldn't be any problem.
Would pay for parts and could provide incentive on request.
Would like to get some more use out of a $150 PSU.
No problems..
Providing its been powered off for a while pull the top off yourself and check out the caps; see if the top is bulged and or leaking.
If so then thats the cause. www.badcaps.net is where you can obtain good capacitors for an excellent price.
I've got some from there on a few occasions for various old motherboards and PSU's.
I've had a few other antec's let go in different manners in recent times.
One took out a new motherboard and burnt the PCB of the power supply. I was told 'after' the power supply was making a high pitched noise prior to letting go. If only I was told prior. :)
Another one simply died with no reason for it doing so.
So no more Antec's for myself they have done their dash. Seasonic all the way.
I believe some of the new Antecs are made by Seasonic. (neo etc) but still only genuine seasonic as you never know when they will change manufacturers.
did a recomendation and build for mid-life-crisie here
met him monday to build it, had monitor issues so finished at home, took it back yesterday
my old case, Soprano thermaltake
E8400 dual core cpu, lightly o/cd to 3.2ghz
2x 2gb 800mhz ram
asus p5ne-sli board, o/cd to 1420mhz ($150)
2x 160gb sata hd in Raid0 aray
thermaltake 750w toughpower psu ($190)
2x 8800gt galaxy gpu's, in Sli mode ($415)
sata dvd, g5 mouse etc
$1200
got 15000 3dmarks out of the box, 16000 with the 7.5% o/c to cpu/mobo
very nice for a budget
3 employees, one from microsoft, one from sun, and one from apple are in a restroom, at the urinals. when the microsoft employee is done he washes his hands, and dries his hands completely with like 10 paper towels. "at microsoft," he says, "we're very thorough." the sun employee finishes, washes his hands, dries them with 1 paper towel. "at sun we're very thorough AND very efficient." the apple engineer leaves without washing his hands, and says "at apple, we don't piss on our hands."
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
