wd are the most consistant hdd's I have come across. (used to make hardware firewalls with em that would need to run constantly and un-maintained for many months). in some cases a couple years
seagate r ok too. nothing wrong with em, they have not proved themselves to me tho.
just steer clear of deskstar drves... they are time bombs
Only issue with WD's I've found is heat. If you run the computer in a poorly ventilated case and the room does not have good aircon on those summer days expect the click of death following a good year of use.
http://au.youtube.com/watch?v=_Faq8tetLRM
jus wondering what ppl use for a browser?
i use firefox with a few choice extensions:
adblock plus
self explanatory really, blocks all those frikkin ads
download statusbar
statusbar that sits at the bottom of the browser, instead of opening a separate window
ie tab
allows u to open a page within firefox using the ie engine
smart bookmarks bar
love this one, strips the name of the url off the book mark and just leaves the logo
url fixer
fixes typos that u put in the address bar
what extensions do u guys use?
oh btw am trying the google browser and it fails... so slow
on firefox i use foxmarks , backs all your bookmarks up to a server so when you go places or reformat you can either login to the site and browse your saved sites or download them exactly how you have them setup
highly recommend this app!!
Firefox 3.0 (haven't installed 3.1 yet)
NoScript (A security feature)
Piclens (Allows better browsing of most picture/video hosts such as youtube, photobucket, etc)
Video download (Let's you download flash videos from youtube, etc)
Abduction (An advanced version of print screen basically)
Firefox 3 on main com
with that plugin that allows you to rip videos off you tube :D
IE7 on my laptop, couldn't be bothered to change.
+1 for the SAU cod4 clan thing.
Edited by Mayuri Krab
im using FF3
and extensions are:
BBCode
English (Australian) Dictionary
Flashgot
Free Download Manager
Google toolbar for firefox
gTranslate
iMacros for FF
Mouse Gestures
Net Usage Item
Paste and go 2
Tab Effect
Tab Mix Plus
Stylish
ones i don't use but are installed
PC Sync 2
winamp
and i didn't like Noscript
    • The price of every automatic S2 stagea in japan has suddenly doubled
    • thanks mate, one of the reasons I even bought it to be fair.
    • I found parts on EFI Solutions webshop that seemed to be the accurate ones. I haven't gotten around to fitting the turbos back on the car yet since I still have to deal with the shitty crack in the engine block. But I'm confident that the bolts I ordered will fit. According to EFI they are also 7-16/24. The reason M11x1 got involved here is because it is apparently very similar to 7-16/24.
    • Well, to be fair to the car I've driven it daily for almost a decade now, although in that time only put on 50k, as it just recently passed 100k miles early this year. For the most part its been fine because I've been able to source parts from AUS like jacks jdm and a few places in Japan, some things like pads have been easy since 300z pads swap right in... I realize its probably at that time in its life i should find a new DD (but I rent and only have so much space, no garage) so new cars just complicate things. As it is older though, I recognize its about that time as with my '67 GTO to maybe side step and find an alternative, but if i can keep driving it... I want to.   That said, I may just look into a local shop that might be able to, problem is the mechanic I work with has limited space as a mom and pop operation, and he's a busy busy man, so id need to find out if he can keep the car in the meantime, which may or may not be practical for him. Maybe I'll just buy one off jacks jdm and get that refurbed /shrug.. just looking at options and what others may have to offer for advice on the matter. Like I said, its hard finding people around here who actually have one, I've had mine 9 and a half years and I've met 3 others, and they are all military, one was oem from 95 with 30k miles (rip that car... guy got hit after someone crossed s double yellow, totaled it)
    • I've noticed my rear springs sag a bit compared to the fronts. I have stock springs and KYB struts. The front wheels are pretty consistent in their ride height, but compared to the front wheels, one of the rears sits 20mm lower, and the other 40mm lower. This negatively affects the ground clearance, and also angles the headlights up. What are some some economical options for new springs? Or information like good spring rates, lengths  in order to find a suitable replacement etc Far from lowering the car, I'd prefer to raise it a bit to keep it ground clearance friendly.
