  • 3 weeks later...
ok if any geeky tech heads are heading to melbourne the 8th of movember you may want to check out Swinburne University for the alien ware launch of Call of Duty world at war lan sound salot of fun :O
http://www.alienware.com.au/party/
taken from GameArena
best quote scrolling through the chit chat
i swear melbourne fking gets all the good **** , when does sydney get stuff like these?.
You guys had a massive parade of people in skimpy outfits just recently. Oh hang on they were all gaylords.... guess that's what you get for living in the gay capital of Australia.
ooooooooooooooooooooooooooooooooooooo
hopefully this installment isnt anything like modern warfare with its amount of online hackers
shall make for interesting LAN competitions
writeoff,
All speedtests really are is in indication of your sync speed. Internode/TPG you should be able to obtain the same sync speed providing the line profile you select targets the same SNR and using the same modem. Some modems connect up a good >1mb quicker.
Typically the ADSL2+ STD profile on internode targets an SNR of 9db. A nice balance between speed/reliability. The Internode highspeed adsl2+ profile targets an SNR of 6db. Still good reliability providing your copper run from the exhaust to the house and internal wiring/filtering etc is all spot on.
I've tweaked mine a little and have the SNR down to 3-4db. Holding stable for 8+days. :)
Well this is Adam internets 8mb plan as were in goolwa, no adsl 2 or 2+ for us here unless we wanna pay ten times the price for Telstra shit service and speed. My girlfriend was also using Second life at the time I did the test which sucks the shit outta my connection.
Edited by Stagstock
ok,
the missus has a computer that we had stashed away in the shed, i pulled it out
a little while ago and plugged him in
shit me, its works, and already has XP installed, its fresh, no files/programmes etc
now, i need to install my optus wireless internet driver, but i cant find it ;)
can i burn it from my lappy and install it on the other comp.?
or does someone have a driver i could possibly borrow?
:P
ok,
:P
copying the program files will not work
i work part time for optus and i know people high up so i can most likely get the software you require ,
the software you require , is it for an OWB ?
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
