this is a bit diff to what i thought, but easier to manage whilst vehicle is in motion i would believe
http://cgi.ebay.com.au/Asus-EEEPC-Solderle...%3A1|240%3A1318
Can you get an external HDD for these, or am i missing the link between HDD and SSD
it has usb ports so you can get external hdd's but you dont want a hdd in the car due to g-forces and shock. ssd = solid state (no moving parts) and can tolerate a lot of shock. They also draw about 1 watt as opposed to the 12-20 watts of a laptop (2.5") hdd - thats one of the reasons the netbooks can get 4 hours of use. Some of them use standard hdd's on the 1.8" scale but these too still draw a lot of power.
That link is for putting the perspect touch sensor inside an existing 901 laptop screen - loads of people have been doing this but I think this is the first one I've seen which doesn't require soldering. SO very tempting, tho it would void my warranty....
-D
OK all you 4 eyed geeks out there ;)
I need to get serious about another build using decent gear without going over the top with price.
Input would be needed and appreciated.....here's a start:
Gigabyte EP45-UD3P M/Board...................$220
Intel Q9550 2.83Mhz CPU........................$413
Corsair Dominator DDR II 1066Mhz 4Gb.......$170
ATi Radeon HD 4850 1Gb.........................$280
Thermaltake 650W 'Q' Fan PSU.................$175
Samsung 2333 SW 23" LCD......................$290
Don't pay tax so these are all EX prices.......anyone do any better or suggest different setup?
Used for office work & video editing.........hence I normally run a Stripe Raid setup.
G-B EX58 DS4....................................$339
i& 920...............................................$469
4GB Kit(2x2G)DDR2 1066 Kingston.......$95
1GB 4850 Gigabyte.............................$287
Thermaltake ToughPower 600W...........$140
monitor personally im looking at this
21.5 “ 2ms HD WS Benq E2200HD Full HD.....$238
i was pretty sure not 100% sure just pretty that i7 uses either
all prices Inc. tax
this is what my mate gets at work
he gets to have a server on a 100Mb link to it too that he can just use to whore on torrents
/jealous
Weird - maximum I've gotten at Hostworks was about 70mbps on speedtest.net ;) .. That said, it does seem to depend on the time of day which suggests it may be a limitation of the testing server rather than Hostworks' connectivity though ...
I would be also be very careful of your friend advertising he 'whores torrents' on this server :)
sorry your right but for a little more than the dominator ram get some Gskill
4G Kit(2x2G) DDR3 1333 G.Skill NQ..............$215
you not going to overclock so you dont need heaps fancy ram Gskill will be quite fine
Steve, just checked out that GB EX58, it's 3 way, so would need 3 x 2Gb which may get expensive to go the i7 route.
Curious to know what the 1600mhz would cost?
Does your supplier issue proper tax invoices?.......otherwise no point if I can't claim the tax back.
Also the 600W ToughPower is noisy compared to the 650W 'Q' I think.
Hi Pete
almost the same as my setup except i run a 4870 vid card and asus m/board
i've had the 9550 running 3.0 ghz on air cooler for 6 months and it is magic!
I would go for a coolermaster tru power psu that has 5 year warranty
G.Skill NQ 3x2Gb DDR3 1600mhz = ~$377(excl gst) and yes his supplier does issue non-dodgy tax invoices :huh:
that's good to know Adrian......because of work files & video work I won't be overclocking as I need it to run very cool & rock stable.
I know Antec also offer 5 yr warranty but apparently Thermaltake have just gone Life-Time?!
Haha, thanks for that Patrick.....problem with DDR3 is that it's still too dear compared to DDR2 so I have to decide whether to spend the extra $$ although the i7 over the Q9550 would be very nice.
Haha, thanks for that Patrick.....problem with DDR3 is that it's still too dear compared to DDR2 so I have to decide whether to spend the extra $ although the i7 over the Q9550 would be very nice.
Unless you're running games, databases or doing hardcore rendering, its a waste. Stick with a quad core system and dual core ddr2, you'll get better value for that.
Incidentally re: EEE pc's, theres a new one coming out from Nvidia which replaces the i945 graphics chip with a 9300gm 3d accelerated northbridge.
Meaning the gfx card wont be neutered and will actually render HD properly. Interesting to note that they will keep the intel atom processor as the CPU, and that the 9300GM has integrated Phys-x capability (tho I cant see many games that use phys-x running nicely on the 9300, even tho it IS a step up).
I'll be keeping an eye out. Any excuse to put World of Warcraft on a netbook and run it across nextG is a good one. :huh:
-D
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
