Hoping that W7 kicks ass on 3 x 36Gb raptors striped, even on a lowly Quad core Phemon 9500! If only the x86 would see more Ram I would add another 4Gb OCZ, but I can't be arsed getting x64 to work properly, as it is my daily/work machine, and Vista64 was a major headache.
Have also sourced a kick-ass 4850 1Gb card to upgrade my existing 256Mb GDDR3 3850 (which has been awesome to tell the truth).
You'll find that most cpu's these days have the 64 bit command set and most people are chomping at the bit to use more than 3.5 gigs of ram (old XP limitation). Windows 7 will primarily be 64 bit I'm guessing since a) most cpus for the last 4 years can do 64 bit and b) people really really want to use loads of RAM, esp with the new i7 platform having 3 way memory (3x2 is what Im getting, will have the option to get another 3x2 for the other 3 slots - 12gigs entry level is phenomenal...
The only driver issues I can imagine are older hardware and certain USB devices. Logitech has been notoriously shithouse for 64 drivers before but I'm interested to see how they treat their customers once W7 is out (I have logitech mice, kb, speakers, joystick, webcam etc - excellent hardware but the driver support (used to) leave a lot to be desired..)
Im really looking forward to this new system. has been 5 years since I upgraded - I'm rather proud of that, and my AMD3200/1gb/36gb raptor will make a sweeet linux box
oh and ive managed to scrounge a dds drive out of spare bits so I has me a tape backup unit too
Going for a cheap vidcard atm since all I play is world of warcraft and that should do it easily... will get a dual SLI beast later on when the next hardcore 3d shooter gets released no doubt hehe
-D
W7 x64 is awesome ive had no drama's with the release i used
this is the video card i bought at christmas time
>>gigabyte 4850 1gb OC<<
that's the exact card I'm running Steve........and yes Andrew, 64bit Vista is a real pain (never had this many issues with XP) but what else do you do if you want lots of memory?!
I just built my system about a month back and using this card: http://www.pccasegear.com/index.php?main_p...roducts_id=8103
That is the EXACT card I am hoping to get. Are you happy with it Vu?
If I get it, it will cost me $200 with 1.5 years warranty still left on it. And I should easily be able to get $100 for my 3850 (since it is an awesome card that plays Crysis at very high res with no problems), so it is a great value upgrade.
Yeah I'm happy - havent got a game I couldnt play yet! Can play Far Cry 2 and Fall Out 3 on max settings @ 1920x1080(max res) and crysis on the same res but with recommended settings. Although I just mainly play CSS anyways lol
Looks sweet as in the Antec 900 case aswell :D
In your case for $100 thats a heaps good bargain!
i understood about 3 words in that :P
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
