Hoping that W7 kicks ass on 3 x 36Gb raptors striped, even on a lowly Quad core Phemon 9500! If only the x86 would see more Ram I would add another 4Gb OCZ, but I can't be arsed getting x64 to work properly, as it is my daily/work machine, and Vista64 was a major headache.
Have also sourced a kick-ass 4850 1Gb card to upgrade my existing 256Mb GDDR3 3850 (which has been awesome to tell the truth).
You'll find that most cpu's these days have the 64 bit command set and most people are chomping at the bit to use more than 3.5 gigs of ram (old XP limitation). Windows 7 will primarily be 64 bit I'm guessing since a) most cpus for the last 4 years can do 64 bit and b) people really really want to use loads of RAM, esp with the new i7 platform having 3 way memory (3x2 is what Im getting, will have the option to get another 3x2 for the other 3 slots - 12gigs entry level is phenomenal...
The only driver issues I can imagine are older hardware and certain USB devices. Logitech has been notoriously shithouse for 64 drivers before but I'm interested to see how they treat their customers once W7 is out (I have logitech mice, kb, speakers, joystick, webcam etc - excellent hardware but the driver support (used to) leave a lot to be desired..)
Im really looking forward to this new system. has been 5 years since I upgraded - I'm rather proud of that, and my AMD3200/1gb/36gb raptor will make a sweeet linux box
oh and ive managed to scrounge a dds drive out of spare bits so I has me a tape backup unit too
Going for a cheap vidcard atm since all I play is world of warcraft and that should do it easily... will get a dual SLI beast later on when the next hardcore 3d shooter gets released no doubt hehe
-D
W7 x64 is awesome ive had no drama's with the release i used
this is the video card i bought at christmas time
>>gigabyte 4850 1gb OC<<
that's the exact card I'm running Steve........and yes Andrew, 64bit Vista is a real pain (never had this many issues with XP) but what else do you do if you want lots of memory?!
I just built my system about a month back and using this card: http://www.pccasegear.com/index.php?main_p...roducts_id=8103
That is the EXACT card I am hoping to get. Are you happy with it Vu?
If I get it, it will cost me $200 with 1.5 years warranty still left on it. And I should easily be able to get $100 for my 3850 (since it is an awesome card that plays Crysis at very high res with no problems), so it is a great value upgrade.
Yeah I'm happy - havent got a game I couldnt play yet! Can play Far Cry 2 and Fall Out 3 on max settings @ 1920x1080(max res) and crysis on the same res but with recommended settings. Although I just mainly play CSS anyways lol
Looks sweet as in the Antec 900 case aswell :D
In your case for $100 thats a heaps good bargain!
i understood about 3 words in that :P
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
