Hoping that W7 kicks ass on 3 x 36Gb raptors striped, even on a lowly Quad core Phemon 9500! If only the x86 would see more Ram I would add another 4Gb OCZ, but I can't be arsed getting x64 to work properly, as it is my daily/work machine, and Vista64 was a major headache.
Have also sourced a kick-ass 4850 1Gb card to upgrade my existing 256Mb GDDR3 3850 (which has been awesome to tell the truth).
You'll find that most cpu's these days have the 64 bit command set and most people are chomping at the bit to use more than 3.5 gigs of ram (old XP limitation). Windows 7 will primarily be 64 bit I'm guessing since a) most cpus for the last 4 years can do 64 bit and b) people really really want to use loads of RAM, esp with the new i7 platform having 3 way memory (3x2 is what Im getting, will have the option to get another 3x2 for the other 3 slots - 12gigs entry level is phenomenal...
The only driver issues I can imagine are older hardware and certain USB devices. Logitech has been notoriously shithouse for 64 drivers before but I'm interested to see how they treat their customers once W7 is out (I have logitech mice, kb, speakers, joystick, webcam etc - excellent hardware but the driver support (used to) leave a lot to be desired..)
Im really looking forward to this new system. has been 5 years since I upgraded - I'm rather proud of that, and my AMD3200/1gb/36gb raptor will make a sweeet linux box
oh and ive managed to scrounge a dds drive out of spare bits so I has me a tape backup unit too
Going for a cheap vidcard atm since all I play is world of warcraft and that should do it easily... will get a dual SLI beast later on when the next hardcore 3d shooter gets released no doubt hehe
-D
W7 x64 is awesome ive had no drama's with the release i used
this is the video card i bought at christmas time
>>gigabyte 4850 1gb OC<<
that's the exact card I'm running Steve........and yes Andrew, 64bit Vista is a real pain (never had this many issues with XP) but what else do you do if you want lots of memory?!
I just built my system about a month back and using this card: http://www.pccasegear.com/index.php?main_p...roducts_id=8103
That is the EXACT card I am hoping to get. Are you happy with it Vu?
If I get it, it will cost me $200 with 1.5 years warranty still left on it. And I should easily be able to get $100 for my 3850 (since it is an awesome card that plays Crysis at very high res with no problems), so it is a great value upgrade.
Yeah I'm happy - havent got a game I couldnt play yet! Can play Far Cry 2 and Fall Out 3 on max settings @ 1920x1080(max res) and crysis on the same res but with recommended settings. Although I just mainly play CSS anyways lol
Looks sweet as in the Antec 900 case aswell :D
In your case for $100 thats a heaps good bargain!
i understood about 3 words in that :P
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
