Win 7 already like Vista has proven to me that it can lick my balls. :)
Seriously if Microsoft are going to continue to build this bullshit admin control into their OS'es I'll happily f**k right off back to XP and OSX. I absolutely refuse to be treated like a computer newbie/moron and have restrictions put on my OS.... and before you fans of 7 get here and tell me to turn some bullshit UAC off (doesn't work anyhow)..... my point is I shouldn't f**kin' have to!!!! :D
you wouldnt like any form of linux then would you. Stick to a mac much more noobish
How is OSX noobish?
If you think it's acceptable that Microsoft want to control what you can or can't do with YOUR OS then that's good for you. Not acceptable to me!
So unticking UAC is to hard for you folks, thats one check box is a real noodle scratcher isnt it.
Maybe you didn't read my post corectly.... Unticking UAC (maybe you're reffering to UAC 'Never Notify' at it's lowest setting) or even running command or .exe as Administator (and I am the Admin) doesn't work, if it did I might not be so pissed about it. The fact that I would have to do this at all is crud!
Error messages stating I don't have necessary permissions. I'm over it and will boot my XP drive now.... :D
I'm a linux engineer so I'm biased, but have you guys ever tried Fedora ? Its one of the best distros out there and has come a long way from when I first started using Slackware back in the late 90's
I dualboot F10 and XP on my asus EEE. the F10 is so much faster, so I use it whenever I don't need to - sadly some things only come with windows drivers so it doesnt have the same level of support as windows, but for a lot of folks its at the stage where they can use it. And its FREE.
And if you don't like unix-like operating systems, there is always the Haiku OS
It's based on BeOS which was a serious player in the multimedia section up until Be Inc folded late 2001 after a disasterous focus shift to 'Internet Appliances' (basically cloud computing and lightweight hardware - they were 8 years too early unfortunately).
Haiku is built from the ground up, is pervasively multithreaded, object oriented and open source (and hence Free). It has the ease of use of MacOS but at this stage is still declared 'alpha' quality but only because the code hasn't been tested on all hardware. So far its pretty much rock solid in everything it does, and very very lean on resources.
I remember when BeOS came out and they had p2-400's and voodoo2 videocards... one of the early demos was to run an openGL cube and superimpose a unique movie file on each face while the cube was rotating... it used I think around 20% cpu due to the super efficient way BeOS deals with media streams...it was way ahead of its time, and while Haiku is a replication of this technology and so doesn't have many 'modern' features, I'm confident the 2nd release of Haiku will be world class. Try it out, even if only on a VMware console and give it a go.
-D
my uac turned off fully, no pop ups at all... im convinced by win 7, it got off to a much better start than the enterprise version of vista ultimate that i have.... i think it was vista ultimate BSoD spec
lol, if Microsoft keep going down this vein and line of thinking, peeps are either gonna head back to XP or like you said, MAC!
some good lol's in this thread atm
UAC is a good thing if ever you've seen my dad on a pc and other complete noobs its something you know we need, not we being me but we being other hopeless users
I'm certainly not someone who needs UAC or will tolerate it.
Steve your not asked to tolerate it just turn it off
As Karl has said its easier for a pro to turn it off than a noob to turn it on
And you know this has come about from the likes of kazaa and bear share mum and dads would download the latest cracked something but they really get a virus
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
