for those of us with rFactor inspect-a-gadget has a dedicated server running all the time to which i has admin :D
download the GTR and the touring car ledgons mods with bathurst and its updates and we can go racing
IP:
>>Touring Car Legends<<
i think Bathurst only needs to be 1.1
>>Bathurst<<
GTR 1.1 mod
>>GTR 1.1<<
you will need to sign up @ rfactorcentral but if you do have rfactor you will go through heaps of downloads as there is heaps of good stuff there :)
for those of us with rFactor inspect-a-gadget has a dedicated server running all the time to which i has admin :banana:
IP:
>>Bathurst<<
GTR 1.1 mod
>>GTR 1.1<<
you will need to sign up @ rfactorcentral but if you do have rfactor you will go through heaps of downloads as there is heaps of good stuff there :bunny:
Just be careful you don't double book the server Steve! JFF use the server too so I should give them a plug and get you guys to check out their site too, they're a great bunch of guys who race regularly and would appreciate new guys to race with...
Check here first before you host a game to see if there is a race or practise scheduled, or join up and race with the guys, they're on most nights racing...
http://jff-racing.my-goo.com/
any time they're not using the server, you're welcome to load up the skyline mod or whatever and any track you like and have a blast!
have fun!
Gadget
with the Nismo 34r mod (the best one to use) I have laid down a 2:08.151 at bathurst.
a 2:07 definitely possible as I'm still tweaking suspension settings and have only done 10 laps in the car so far.
Tips...
1, soften suspension
2, change gear ratios till you can get 308KMh down conrod with rear wing on 2 and front splitter on 2
3, MUST increase brake ducts to as big as you can. Brake fade is a MAJOR problem with brake temps over 1100degrees!!! brake at the kink in the end of conrod, and pump the brakes, brake earlier here, because by the final turn, the brakes don't get enough time to cool and you can end up in the fence with no brakes!
4, use torque split of 35 front 65 rear. or 30/70
5, increase tyre pressures and play with camber settings till you have even tyre temps across the tyres. cold in the middle, add pressure and vice versa.
6, slow in, fast out
7, drive smooth, smooth is fast, don't try to drift, it will, but don't try!
8, raise rev limit to 9000RPM
hope that helps, and gives you something to aim for!
Gadget
Edited by inspect-a-gadget
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
