that is an awesome setup.....but i am with you on this Andrew....water and electrical components dont mix :)
water cooling is only dangerous when you use water ;P
there are proper coolants available that are non conductive, as well as all-in-one premade units like the corsair cpu cooler found here
http://www.pccasegear.com/index.php?main_p...oducts_id=12235
which i have used on several of my recent builds - theyre awesome...
otherwise, you can completely immerse your components in an inert solution, such as here :
http://yourtech.typepad.com/main/2008/10/l...right-here.html
one of the earliest examples of this they used canola oil - which obviously isnt great to get on components as its thick and a pain to remove off components - the proper coolants evaporate like alcohol once components are removed from the solution bath
its good stuff, but way expensive for the most part
-D
Thats a sexy piece of hardware I reckon... pity about the price.
quite pretty but there is a good reason the cost is so high, and that is the atx connector backplate at the rear of the motherboard - sealing that section off to stop leaks is pretty difficult however these guys make their own gaskets and use a brace to keep the pressure on the case
incidentally some mainframe/datacentre computers are 100% immersion watercooled because of the huge amount of heat distributed from all the cpu cores
gonna buy that very corsair water cooler next fortnight - hopefully this coming summer it'll be sufficient to keep my system totally cool
-D
Firefox is giving me the shits.
Go do add this theme: https://addons.mozilla.org/en-US/firefox/addon/64006/
Tells me i am using 3.0.8, go to help, about firefox, says version 3.6.4. Tried restarting, no good. wtf? do i uninstall and reinstall?
Some help required lads, my sis tried to connect to the net the other day only to have firefox chuck up a message that it was configured to use a proxy server that was not allowing connections or some jazz.
I went into internet options and selected 'auto-detect proxy setting for this network' so i can go on the net, just wondering if I should leave it on that or will it be (more) vulnerable to attacks/people fking with my pc, or could that even be the case as to why the error came up in the first place?
Only tick it if she's running a proxy server... which I highly doubt unless the PC is in a business location.
THat option on or off wont change anything to do with people attacking it.
Excuse me ladies and gents.
It's not so much computer oriented.
Do any of you know how to make my LG BD560 blu ray player region free? I remember doing it for my old LG dvd player years ago. It was some code I had to enter in.
I am having trouble finding anything about unlocking the region code on the net.
Any help would be fantabulous. PM me if ya can.
Saves cluttering up this thread with my useless shiznit
    • A lot of the trim pieces on the E39 are super brittle and just dissolve when you try to get them off. It looks like a previous owner has used what can only be described as an industrial construction foam adhesive to glue down a tiny piece of trim.  Unfortunately this part of the tailgate is starting to rust because of how much shit is in here. This is stopping the water draining and there's a big build-up of dirt that is just staying wet. How can I remove this? Would a flap disc get rid of this?  I think this car spent a lot of time inland. There's so much light coloured, fine dirt and dust everywhere.  Sorry for the pic. I've cleaned this all up now so I'll get another pic of it clean today.
    • Surely, just about any shop that has done a Skyline (or Supra, or RX-7, or EVO, or WRX) will have done E85. But perhaps you need to specify what type of car, what type of engine, what ECU, you propose to be using.
    • Try an oil additive. There's a couple of options for "easier shifting". These are essentially a similar idea to what Redline put into their Shockproof gear oils. I had a 2nd hand R33 (in fact, as of right now, it is still in the car) that simply would not engage any gear with the engine running, with normal gear oil in it. We dropped that and replaced it with Shockproof lightweight, and suddenly the gear lever did what it was supposed to. At a cost, of course, of the then ongoing damage to internals done by running Shockproof. But the synchros were already totally uninterested in life, so there was no loss.
    • It always ends with the car burning down.
    • I see what you posted, but how could a warning light be going on and off if there is no sender for it?  The only other explanation is that the wire that used to go to the sender from the warning light is earthing somehow in the loom or at the connector, or that you have connected the warning light wire to something (maybe the temp sender?).
