all depends on usage and whats enabled
for me i disable bluetooth and leave GPS and wifi off when im at work
i can take the phone off charger when i get to work @ 6:45am have the phone automatically check for emails every 10mins play some games at smoko and lunch plus checking emails and make it home with a little bit left @ 4:20pm
what battery life are people getting with there htc/android?
Depends on the phone, usage, etc. With mine, I'll get about 1+1/2 days with pretty heavy usage, Wifi, etc. Can stretch it to 2 if I don't use it too often. I charge every night anyways so it doesn't bother me. Unfortunately the days of getting 5 days out of a full charge is long gone and left behind with the old 3315 Nokia's. However what these phones do these days it's not surprising battery life isn't the same
lol Dion cause i saw edit i wont spank ;)
agreed Luke i use mine like a micro computer when im away from my desktop this is my palm pc
with Android and the use of Team Viewer i can control any of the PC's in my My Partners list
edit: I'm just being a dick now.
My iPhone 4 lasts about the same, 1 day with heavy usage, 2 days without.
No surprises, most modern day smart phones have around the same usage. Unfortunately battery technology has remained relatively stagnant over the years in comparison
yeh sweet, i get a full day of heavy usage with full screen brightness.
gotta say you would think battery technology would improve.
Rooting the phone, installing a custom ROM and a modified kernel will give you better usage, how much exactly I'm unsure but there's gains to be had
I've got my email set up to 'push', so it doesn't check it on it's own, but I get it as my email account receives it.
Sounds like it may be a network issue Damo, my phone is fast on the net pretty much everywhere.
Edit: Just ask the people at Kadina who stole my phone and were watching Redtube on it LOL.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
