all depends on usage and whats enabled
for me i disable bluetooth and leave GPS and wifi off when im at work
i can take the phone off charger when i get to work @ 6:45am have the phone automatically check for emails every 10mins play some games at smoko and lunch plus checking emails and make it home with a little bit left @ 4:20pm
what battery life are people getting with there htc/android?
Depends on the phone, usage, etc. With mine, I'll get about 1+1/2 days with pretty heavy usage, Wifi, etc. Can stretch it to 2 if I don't use it too often. I charge every night anyways so it doesn't bother me. Unfortunately the days of getting 5 days out of a full charge is long gone and left behind with the old 3315 Nokia's. However what these phones do these days it's not surprising battery life isn't the same
lol Dion cause i saw edit i wont spank ;)
agreed Luke i use mine like a micro computer when im away from my desktop this is my palm pc
with Android and the use of Team Viewer i can control any of the PC's in my My Partners list
edit: I'm just being a dick now.
My iPhone 4 lasts about the same, 1 day with heavy usage, 2 days without.
No surprises, most modern day smart phones have around the same usage. Unfortunately battery technology has remained relatively stagnant over the years in comparison
yeh sweet, i get a full day of heavy usage with full screen brightness.
gotta say you would think battery technology would improve.
Rooting the phone, installing a custom ROM and a modified kernel will give you better usage, how much exactly I'm unsure but there's gains to be had
I've got my email set up to 'push', so it doesn't check it on it's own, but I get it as my email account receives it.
Sounds like it may be a network issue Damo, my phone is fast on the net pretty much everywhere.
Edit: Just ask the people at Kadina who stole my phone and were watching Redtube on it LOL.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
