I have the following for sale:
1) R33 GTST series 1 front + rear seats (very good condition) front = $70each/rear = $70
2) R33 GTST factory front + rear shocks with springs (not sure on condition)- $100
3) R33 GTST low sitting King Springs (good cond i never used them) - $100
4) 6 Apexi 555cc injectors for R33 GTST. 1 is not working may need service or the like - $600
5) R33 GTST series 1 original cams - $200
6) Tomei adjustable cam gear (brand new) - $250
7) R33 GTST series 1 steering wheel - $30
8) R33 GTST series 1 factory computer - $100
9) R33 GTST factory plenum (top + bottom) - $70
10) R33 GTST original Nissan plenum gasket (not used in plastic) - $80
11) R33 GTST series 1 coilpacks - $20 each
12) R33 GTST factory intercooler (good condition) - $50
13) XF throttle body - $50
14) R33 GTST front + rear doort trims (good condition) - $30 each
15) R33 GTST factory boost solenoid - $20
all items are negotiable. want to get rid of them asap.
https://www.sau.com.au/forums/topic/108829-r33-parts/
The coil packs have around 90,000kms on them. I changed to splitfires as i was intending to run 20psi boost or more. not sure on condition. i dont know how to check but you are welcome to.
ActionDan i sent you a PM. did you get it?
ill post pics up tonight..
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2005818
sorry ActionDan wrong person. i have some guy wanting the springs. not sure on the part number. they are the genuine nissan item. if you call nissan im sure they can help you but i have no idea when it comes to suspension.
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2005825
3) R33 GTST low sitting King Springs (good cond i never used them) <--- how can that be a genuine nissan item?
THOUGHT U WERE AFTER THE STABDARD SPRINGS/SHOCKS. THE KING SPRINGS ARE NOT STANDARD BUT ARE THE SUPER LOWS FROM MEMORY? FROM WHAT THE GUY TOLD ME THE RIDE HEIGHT IS 45MM LOWER THAN FACTORY WITH THEM. I DONT KNOW ALL THE DETAILS JUST BOUGHT THEM AS A TEMPORY SOLUTION FOR THE FACTORY SPRINGS BUT NEVER GOT THEM ON.
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2006156
hey mate, do you have a number i can ring? if you want, give me a bell or send me a msg on 0413 032 208
Im interested in you intake plenum and your XF TB. O, and i live in south coogee, so nice and close for pickup :D (btw, what car do you drive? mighta seen you around? )
-Tom
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2006782
Im interested in you intake plenum and your XF TB. O, and i live in south coogee, so nice and close for pickup ;) (btw, what car do you drive? mighta seen you around? )
-Tom
Anyone can call me on the following number. 0410 580 010. i work weekdays from 9to5.30 so if i dont get the phone until then just send me a text. Cheers
Boro..
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2007656
Croat,
PM sent. Want to buy the steering wheel, item number 7:
"7) R33 GTST series 1 steering wheel - $30"
Let me know your reply at [email protected], or alternatively SMS me on my Vodafone prepaid number: 0406 047 490.
Much appreciated,
rav4lution
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2016407
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
