  • Replies 73
Posted Images
Well as ur gona find out soon enough, when things are'nt as simple as flat panels and u have tight corners to get around the fibres dont always wanna play ball n stay where they should. So after u finish laminating ur part you then put on a release film, then some breather (which basically spreads the suction around ur part and absorbs excess resin too) and then bag it. So what u end up with is the better part of 1 Bar of pressure all over ur part. For a flat panel what id do is have another flat surface that is waxed to put on top (make a sandwich of the laminate) and then add some weight on it, this basically gives u a thinner better consolidated laminate. The vacuum bagging method is great but it also means buying the extra's that go with it. (Release Film, Breather, etc)
Clearly money well spent if u wanna make trick bits. All the best !!! Make sure u use gloves n have some acetone handy to wipe up the spills.
cheers for the run through..
have you got any ideas on what materials are the best to use as a mold creator of complex items...
basically i was watching monster garage. they had a foam type composite that the guy cut up using a saw .. was light but hard, then he covered it in fibreglass to make the item.
i want something that i can manipulate then take the mold off that in fibreglass so you can produce the item..
does that make sense?
well in ur case if ur only makin some one off bits for a play around then you can use high density foam/ MDF/ wood but ur surface will have to be either painted n polished in the case of the MDF/wood or sealed in the case of the foam. The high density foam also disolves in acetone so be careful there.
This process will form whats known as a pattern and from this pattern u get ur mould and then off ur mould u get a part... to be really cheap n simple id go with the MDF, u also have patten forming clay... Look im sure there is alot more stuff out there that i dont know off, but to start with these are very do able options. Maksure ur mould is thick and rigid, use a lot of chopped strand matt to bulk it up....
yeah i think i saw that clay stuff at the fibreglass suppliers.. looks just like play dough...
do you need to seal that? or does the resin just not stick to it?
think i read somewhere last year that it will not stick to play dough .. might be the same for the clay.. cos it re-usable from what i read on the packet
welcome to the world of carbon, i'm willing to answer any questons people may have. I'm actually a composite technician and work with it everyday. i work at custom carbon here in brissy good ol vacuum bagging least you guys are on the right path... beware stuff ups are a plenty in the world of carbon. Good luck
yeah the website has been down for a while, the boss is getting it all redone
i been on his case about it, guess its done when its done.
what R33 stuff you want pics of? for R33 the moulds we have are
Modified blitz 400r full kit
GTSt bonnet series 1
GTR bonnet series 2
GTR front grill
GTR lower lip
Bootlid that sits flush with rear panels
pillar mount gauge holder
GTR wing just the blade
door sil panels
I'm pretty sure thats it i'll get onto the computer at work tomorrow and get some pics. and post them up whan i can.
Oh and craved you still have to wax mouding clay/ play dough or plasters or the resins will stick to them.
GTR bonnet series 2
GTR front grill
GTR lower lip
door sil panels
are your products carbon overlays or pure carbon ?
Does anyone fabricate carbon front gaurds for R33 gtst's?
There is a magazine called performance build up's which has released a few articles on working with carbon/kevlar. That may help answer a few questions people have.
refer to pics above
i found a company in japan that does them, but they were really expensive...around 2k each from memory
Yes, 2k is out of most peoples budget for gtst upgrades.Is the company called Bee-R?
I also heard somewhere about someone in SA that fabricates gaurds. Not sure if they are carbon or fibreglass. Have you heard of of anything along these lines?
Steve
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
