mine is doing that, ideling at 1500/1400rpm
Its the round gold thing with an electric clip going into it, its connected to the AAC valve. (on the back of the intake plume)Thats what mine was.
u can test it by disconecting that clip when the car is on. if its working the revs should change. if the revs dont change its stuffed
https://www.sau.com.au/forums/topic/109036-idle-speed/#findComment-2011623
where abouts is the gold thing located?
https://www.sau.com.au/forums/topic/109036-idle-speed/#findComment-2011832
to find an air leak buy a can of carby clean and spray around suspect area. when revs pick up you have found you mark......dont use water on things limke manifolds for air leaks.....water doesnt compress like air and has a tendancy to bend bits inside motors if to much goes in......:D
https://www.sau.com.au/forums/topic/109036-idle-speed/#findComment-2019794
ok, have noticed that the problem is mostly in the morning....
i have tried letting it warm up for a while, but it doesnt go away
if i goto work in the morn, park it and say start it at lunch, it will rev just under 1000rpm
its almost everyday that this happens and its rather annoying....
will have a play around on the w/e
thanks guys
https://www.sau.com.au/forums/topic/109036-idle-speed/#findComment-2021355
has anyone thought about the throttle cable?
it may be sticking a bit!
my 32 idels around 900-1000rpm an sumtimes it idels at 1900- 2000rpm then drops back down to normal rpm. an because the the throttle cable is sticking a bit.
ahhh who would of thought of that.
https://www.sau.com.au/forums/topic/109036-idle-speed/#findComment-2021444
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
