Hence why I asked for it :P Anyone know where I can take it to to get the design made into a sticker? I've got the next few days off work so I could get something organised, make up a batch of say 20 or 30 and go from there...
I have found a local business that specialise in printing decals for cars, would just need to get a cost estimate from them and see what they'd recommend whether it be a vinyl sticker, or a transparent sticker etc.
So how about something like this? (the black is emulating the window to show you what the sticker would look like)
i'm getting quotes now. The prices vary alot on sizes and quantity.
First up I'm asking for a price on 100. The wide one i was thinking 200mm and the square one 150mm
reasonable large. Small ones would be alot cheaper.
Biggest problem is someone would have to outlay the $ to get them all printed then sell them all off.
okay. These are quite large. I am not sure if making them smaller would work out cheaper; possibly would but would also be harder to die cut.
wide stickers
Size: Approx 200mm x 40mm
Substrate: Vinyl Computer Cut Stickers
Vinyl: Avery 7 year white vinyl + Avery 7 year red vinyl
Quantity: 100
$264 inc gst
square stickers
Size: Approx 150mm x 145mm
Quantity: 100
$352 inc gst
Edited by GFXman
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
Ă—
Ă—
