1998 Er34 GT-T Sedan
2.5 Litre NEO6 Turbo engine
4 Speed tip-tronic auto with steering wheel shift
73,000km’s
LSD
Super HICAS
ABS
Airbags- two in the front and 2x side impact
Traction control
All power options
3.5inch Blitz Nur exhaust (plus silencer)
3inch Turbo dump and front pipe
600hp Hi-Flow CatCo Catalytic converter
Pod filter
600x300x76 front mounted intercooler
Profec A Electronic Boost Controller
Turbo Timer
SAFCII Black (Tuned by Hyperdrive)
Xenon lights with adjustable tilt
After market stereo with MD player (jap one ie shitty radio) and Alpine Type R subwoofer
Serviced every 5000km’s with Mobil 1 and replaced plugs with iridium’s
Power output of 250rwhp @ 10.5psi. Was also tuned richer than most people get to keep it in the green.
Stock exhaust and filter still in garage. But stock IC has been sold. Comes with spare tyres 4x Bridgestone G-Grid IIs with lots of tread left (taken off for compliance).
Now replacing rear bumper...
Cost of ownership...
$901 a year in insurance and im 22 with 60%NCB.
Costs about $60-70 to fill with BP Ultimate and gets between 450-550km's depending on how its driven.
Servicing costs about 70 bucks every 5000 (im sure you can do it every 10 but I wont)
Asking 23k ONO
PM or email... [email protected]
*Added more pics*
Edited by SnRuB
https://www.sau.com.au/forums/topic/109261-r34-gtt-sedan/
the missus wants that auto :O
I must stay strong for the manual... :ninja: hehe. good luck with the sale.
btw...got pics of that crack in the bumper?
Edited by mickey
https://www.sau.com.au/forums/topic/109261-r34-gtt-sedan/#findComment-2073244
the missus wants that auto :laugh:
I must stay strong for the manual... :D hehe. good luck with the sale.
Yeah i know where you're coming from. Same thing, just 12 months ago :-)
My cameara is stuffed so im in the process of buying a new one. But to describe it.... Its the right rear corner. It went into my other car at about 2km/h and is more warped that it is cracked. A few people said i could repair the crack and get it sprayed but a new kit and spray is only 1k more than getting it back to stock anyway.
Let me know if she wins and you want to talk..
Ben
https://www.sau.com.au/forums/topic/109261-r34-gtt-sedan/#findComment-2073844
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
