Hey all couldnt open the pdf thingy on the safc 2 install, just wondering if both knock sensors needed to be wired up, we only wired up 1 and it seems to be working but why would we need to wire the other one.
Weve hooked the purple wire for the knock sensor up but are unsure of the colour of the wire for the other knock sensor.
Cheers for any help, Semo
https://www.sau.com.au/forums/topic/109446-safc-2-wiring-drama/
nah you only have to wire it upto one of the knock sensors..
lemi know if you cant find another copy of the pdf and ill send u one ive got..
all this stuff's covered in the pdf :O
Thanks mate!
I've tried to open various pdfs on 3 different computers but it doesnt open, it just says it needs to update, then says no updates are available.. So i really dunno whats going on there.
Are you able to copy/paste the info in the pdf into a word document?
That would be great!
Thanks,
Semo
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
