Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest Boxhead
cool... hey guys im stayin up all nite well till atleast 4:30 hahaha, look at the rage play list!!! its awesome from 3am
3:00am PDA - INTERPOL Remote Control
American Hearts - PIEBALD Independent
Bleed American - JIMMY EAT WORLD Universal
The Middle - JIMMY EAT WORLD Universal
Sweetness - JIMMY EAT WORLD Universal
A Praise Chorus - JIMMY EAT WORLD Universal
In This Diary - THE ATARIS Sony
Adam's Song - BLINK 182 Universal
3:30am Cailin - UNWRITTEN LAW MDS
Is This The Part? - ONE DOLLAR SHORT Fest/Mush
Not The Same - BODYJAR EMI
Lozin' Must - MILLENCOLIN Shock
Dopeman - LESS THAN JAKE EMI
Punisher - FRENZAL RHOMB Shock
One Said To The Other - THE LIVING END EMI
Nothing - A Warner
4:00am Society - PENNYWISE Shock
43210 - 1 - THE VANDALS Shock
I'm The One - THE DESCENDENTS Shock
Fat Lip - SUM41 Universal
San Dimas High School Football Rules - THE ATARIS Shock
Story Of My Life - MILLENCOLIN Shock
Master Celebrator - NO FUN AT ALL Shock
All The Small Things - BLINK 182 Universal (MCA)
Longview - GREEN DAY Warner
Lonesome - UNWRITTEN LAW MDS
Satellite - ONE DOLLAR SHORT Fest/Mush
4:30am Josie (Everything's Gonna Be Fine) - BLINK 182 MDS
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
