Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest 87vlt
Originally posted by BelGarion
ill take the catback off, it will still have 7psi below 5000rpm and 9psi above 5000rpm
thats the way r33s are from factory.....
hell if ur that desperate to prove it wrong, ill take my exhaust off and drive it round the block
1. ull see no change in the boost
2. ull pass out from the gasses
3. cops will be called cause of noise
but it will still be 7psi below 5krpm and 9 above it
4. you would loose power by removing your exhaust. I am in that situation right now cause my exhuast is getting re-fitted on Monday. It sounds like crap and goes like crap.
5. I got a exhaust and my boost went from 6 psi to 7.8 psi. Almost a 2 psi gain.
6. removing your exhaust is not going to increase your boost. You've already had a boost gain. try fitting the original restrictive factory exhaust.
7.
thats the first time I've heard that. I'm almost certain that factory boost is between 6 and 7 psi - well according to HPI and Zoom anyway, unless of course they have no idea what their talking about (which could happen) and in which case you would be right.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
