Queensland Wasteland
WaNaSkYlInE
where is it damaged, if its in a straight peice of pipe they can just weld a new one too it but if its on a bend, some hks ones are mandrel bent it can be quite expensive.
gold coast custom exhaust are good, but it really depends on where u are. any exhaust shop can do good jobs.
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest WaNaSkYlInE
not exaclty sure where it is damaged
THe cars so low i dont think my mate has had a real good look at it yet! All he knows is that its making a whistling sound and its coming form under the back passenger seats
will power output be affected tho after repairs are done?
depends what kind of welding technique they use, which all depends on how much they pay him.
my cars quite low also, but u can get under it. hopefully he jsut riped a gasket out from between a flange plate. $5 fix and $10 labour i reckon.
but get ya mate to have a good look.
Guest Boxhead
is that internal? or external? hahaha
i dunno man, if everything goes to plan, ill be there, but you know what its like with car things, never on time, i have car booked in tomorow for pod box made by aluminium fabricators...
and then hopefully wednesday or thursday car can have the blue slip, with a bit of a little tune, like brake pads etc
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
