Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Get a 3000p pressure plate organic clutch. They rock :D
I'm sooo full. Bacon egg and onion sandwiches rock.
Andrew went to the shops and bought my some easter present and he didn't know which one to buy, so he bought all 4. He was going to buy 6 but thought i'd get cranky at him.
I've got plenty of chocolate to get through, but I can't eat it :)
Nah.. It's not. Trust me. I'm as weak as a fly and its awesome.
It's hard at first but once you get used to it, it's awesome.
Remember its an hydrolic clutch so that helps. You wanna feel heavy, you should see how hard brutis' clutch is. It's 1650p pressure plate and it's not hydrolic. It's a ****er to drive. I can't physcially push the clutch in myself.
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
