Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Hehe it was funny cos i heard people talking about the mag cos everyone got one and all i could here was Nizmo - i was starting to get a complex hehe
boss was around sorry for delay!
Guest 87vlt
Here's a joke.
Theres a guy cruising along in his shiney red sports car (a skyline if you wish) going over a bridge. A Policeman with a radar sees the guy and pulls him over for speeding. The officer tells the guy he was speeding and hands him the ticket. The officer asks "so what do you do for a living to be able to afford a car like this?". The guy from the sports car replies "I'm a rectumstretcher".
The officer says "your a what?, what does that invole?". The guy replies "well to start off we get a bit of lube put it on two fingers and insert them, and slow start to strech it, working your way up to two hands. You keep on going until you get your arms in, then your legs and until you can almost find your whole body in." The officer asks "What would you do with a 6 foot arsehole?"
The guy replies "put him on a bridge and give him a radar gun"
hehehehe
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
