Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
boxhead posted this
have such a hard life, playing golf, hahahaha had 9 holes today, michael my friend almost started a fight with a 50 yr old, but the 50 yr old started it, coz we were slow, they were assholes, instead of askin to go infront.. so they tryed to hit balls at us..
did anyone else notice this date on this is ghey....
umm same with yours paul, and i keep gettin the message 1 post per 30secs
Military obsession doesn't imply violent personality.. don't believe me? Fine, you're f*cking dead!
President of...
---team RAASAUM---
(Rebel Alliance Against Skylines Australia Moderators)
[MR. T. voice] KIDS LET THAT BE A LESSON TO YA, DRINK YA SCHOOL, DONT DO MILK AND STAY IN DRUGS [/MR. T. voice]
"Being grown up isn't half as fun as growing up, These are the best days of our lives, The only thing that matters is just following your heart, And eventually you'll finally get it right" - The Ataris - in this diary
schizophrenia is better then being alone!
One of the most talked about whores in the SAU mod section.
Where do all the porn stars go? They all become volvo driving soccer moms
Guns dont kill people, I kill people
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
