Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
well, this will be my last whore for a while... no computer really in melbourne.. but when i get my new place i will come back up and pick up my computer and start whoring again.. will drop in and say hi every now and then :D
:yawn: have a 7am flight from brissy tomoz.. better start packing.
Originally posted by MotoX
nismoman18: DONT USE A HAMMER.
i put em on my computer desk and pushed em in.
then used my didital calipers to measure it correctly. and a small screwdrive to get it perfect.
but if u wanna use a hammer get a sledge hammer
i havent read any thread before this.. but im assuming your talking about your plugs wayne...
have u ever heard of a feeler guage... they r under $2.. so dont be a tight arse.. haaha
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
