Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
bought a new washing machine the other day.. now just need to convert all other appliances to "turbo".. :(
http://www.lge.com.au/productsPOP.asp?subt...uctgroup=Washer
"6.5kg Turbo Drum Washing Machine".. rofl :D
Guest 87vlt
Originally posted by Skyrine-Dave
HOLY SHIT!!! :|
he offered me $300 and i was gonna say to just find me some 550cc injectors.. =$350 or so
what if its just a thrust bearing high flow
well it cost around 1600 bucks to a high flow a non ballbearing. a high flow ball bearing costs a tad under 2 grand to make. and you've gotta have a turbo ti begin with.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
