Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
oooo uniform - what do u do? if u say cop i will ring your bloody neck haha
QLD aint always fine - got over there - started raining but it was 40 degrees in perth - shouldve stayed home for my bloody holiday haha
Originally posted by Nizmo
not too bad Erin - life hasnt been all strawberries n cream fo rme lately but u get that.
How did the job hunt go? any results?
What's up??? I haven't been reading through all the crap :D
Job hunting is still going. I turned down one today because the temp contract was less than what I've got now.
I've been extended where I am till September 30 now so that's a bonus. ATM I'm applying for a job at the Academy with the Recruits. So I'll get to work with all the young, fit and cute recruits :)
:drool:
haha becareful your folks may put u in private school (unless u already go) like they did to me to try n get me to do some work. Thing was im bright enough - got into all extra classes - just i hate homework and have a short attention span - so that didnt work n i got kicked outta school by my folks to go find a job haha
Check this out:
http://crew.tweakers.net/JvS/zooi/realhussein.swf
friend just sent it to me - friggin funny.
Guest neoGT-25
haha i used to go to a private school :D it dident work in the first place LOL they sucked!
i try doing work i just hate hw like you and i always talk in class so i get raped by the yr leval co-ordinator :) shes such a bitch... ive never heard her talk normal... shes ALWAYS angry and screaming
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
