Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
acrylics are quite expensive - my mum has them done - she keeps breaking them too! hehe i had naturally long nails then i went back to the car industry and they started breaking cos i was doing more than sitting on reception everyday - could grow them again i guess but i like my claws short :D
hmmmm i cant talk about cars tonight - this is going to be hard - already gone to this guy "im a revhead" and he's like im a jock thru n thru - beware of the guy that calls himself a jock me thinks.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
