Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
alright page to me
ok, so lemme know what yas think
im thinkin gettin a old vid camera that has rca outs ect on it, then i mount it in a perspex box cussioned insides ect and securly mount it so the lense has view outta the front bar (one of the holes)
possibly disconnect the lcd screen if it has one, and run some cables into the cabin and connect the screen in there, anyway its a cinch to get the vid onto a computer as i have a digital vid camera, but i aint stickin that down in my bar where theres a chance it might get hit by a rogue stone :| if anyones seen my car theres a piece of guard hanging down, a ****ing rock ripped it off its mount last run in the hills
yer i wanna kick something off for thursday nights on the goldcoast, friday night is usually the night i drink with mates and stuff, sat night is usually bwcp and show off night, i reckon regular fortes into the moutains or just cruising round on thursday nights down here could be a good thing, and as we all know, i know my way over tambo mt if anyone wants me to lead a cruise over that, bit sketchy in the wet tho, specially with those hairpins
Guest Boxhead
yes i know we went sideways and at 100kmph... but i thought it was a bit of lockup of brakes and interia drift...
anyway ill have a speak to the mrs(im meant to be stayin home tonight and having a nice nite in with her) and also maybe ben a mate, ill get back to you in say an hr and a bit ok.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
