Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
hmmm so paul how would u know i had them tho eh? unless i heavy breathed all over u or got some pashing action happening u would never know! besides im coming straight from work to ur house - no anchovies but a lot of prawns n salmon n morton bay bugs n octopus was consumed today so i should have fishy breath like my cat :P
paul uve only seen my room once and i thought u were crashing there so i tidied it just for u - otherwise u cant get in the front door cosof the clothes on the floor!
Shaft - QLD are always here when i need them :P ive been adopted by them :P
obviously not paul - i was away for half a day and the whoring in two states just came to a crashing holt! even u got bored.
*starts singing from my fair lady* "ive grown accoustmed to her face ....*
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
